[postgis-users] Installing PostGIS 2.3.8 over PostGres 9.4, Windows
Mauro Gregorio Binetti
maurogregorio.binetti at gmail.com
Tue May 29 09:18:42 PDT 2018
Hi Regina,
first of all thank you very much for responding so fast.
Your assumption is correct. I installed PostgreSQL 9.4.18 using BigSQL
distribution.
Your explanation is very clear to me now.
I need to use version 9.4 of PostgreSQL so, I understand I have to start by
changing this one. My reference must be https://
www.enterprisedb.com/downloads/postgres-postgresql-downloads
Correct?
Then I can repeat PostGIS installation using the same zip file:
https://winnie.postgis.net/download/windows/pg94/buildbot/postgis-pg94-
binaries-2.3.8devw64gcc48.zip
Correct?
Regards,
Mauro
On Tue, May 29, 2018 at 5:02 PM, Regina Obe <lr at pcorp.us> wrote:
> Which distribution of PostgreSQL are you using?
> It looks to me like you are using a distribution incompatible with the
> EDB distribution which the 9.4 binaries I built were built for.
> For example if you are using BigSQL, only PostgreSQL 9.5 and above
> binaries on Winnie will work with that.
> The reason for this is
> Prior to PostgreSQL 9.5, EnterpriseDb used to compile their windows
> versions with FLOAT8PASSBYVAL = false
> So to accommodate that, I built < 9.5 with FLOAT8PASSBYVAL = false
> However BigSQL windows distributions have always been built with
> FLOAT8PASSBYVAL = true
> So the 9.4 builds I built for EDB WILL NOT WORK with 9.4 BigSQL
> In Version PostgreSQL 9.5+, EDB changed their windows builds to build with
> FLOAT8PASSBYVAL =true as well
> So from that point forward, the builds are compatible.
> http://postgis.net/windows_downloads/
> (that's why I put a note on that page that for BigSQL 9.5+, you can use
> the binaries here if you want extra stuff. I probably maybe should have
> explained that better (and put a big DO NOT USE if using < 9.5 on BigSQL)
> Thanks,
> Regina
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Mauro Gregorio Binetti
> *Sent:* Tuesday, May 29, 2018 10:29 AM
> *To:* postgis-users at lists.osgeo.org
> *Cc:* Mauro Gregorio Binetti <maurogregorio.binetti at exprivia.it>
> *Subject:* [postgis-users] Installing PostGIS 2.3.8 over PostGres 9.4,
> Windows
> Hi guys,
> I have downloaded the subsequent zipfile:
> https://winnie.postgis.net/download/windows/pg94/buildbot/ postgis-pg94-
> FOr the subsequent command:
> "%PGBIN%\psql" -d "%THEDB%" -c "CREATE EXTENSION postgis;"
> shown in bat file: makepostgisdb_using_extensions.bat
> I have the subsequent error:
> *ERROR: incompatible library
> "C:/__APPL/pg94/../pg94/lib/postgresql/postgis-2.3.dll": magic block
> mismatch*
> *DETTAGLI: Server has FLOAT8PASSBYVAL = true, library has false.*
> I have modified boolean flag value to false in subsequent files:
> · pg94\include\postgresql\server\pg_config.h
> · pg94\include\pg_config.h
> but I continue to have same error.
> Can you please give me some advice.
> Thank you in advance.
> Mauro
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180529/dc149d13/attachment.html>
