[postgis-users] netcdf files deprecated in raster2pgsql?
John Payne
drjohnpayne at gmail.com
Mon Aug 26 09:53:31 PDT 2019
Hi Regina, thanks for your answer. Your reply ended up in the wrong email
folder so I didn't see it until just now.
I'm using the BigSQL distribution (i.e., PostgreSQL and associated
libraries as provided by bigsql.org).
SELECT postgis_full_version() gives this:
"POSTGIS="2.5.0 r16836" [EXTENSION] PGSQL="110" GEOS="3.6.2-CAPI-1.10.2 0"
PROJ="Rel. 4.9.2, 08 September 2015" GDAL="GDAL 2.2.0, released 2017/04/28"
LIBXML="2.9.0" LIBJSON="0.12.1" TOPOLOGY RASTER"
Sounds like maybe I should contact BigSQL.org with the question. I
appreciate you giving me some perspective.
John
On Wed, Aug 21, 2019 at 10:13 PM Regina Obe <lr at pcorp.us> wrote:
> Which package system did you get your PostGIS from?
> What you can load via raster2pgsql depends on what drivers your GDAL is
> compiled with. It might have been an omission on the part of the packager,
> like perhaps in past they used the standard base packages to get GDAL and
> because GDAL from base is always old, they might have compiled their own to
> ship to get newer GDAL and didn't include the kitchen sink that the base OS
> package includes.
> NetCDF is not in the default compile of GDAL as it requires additional
> dependencies.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> Behalf Of J Payne
> Sent: Wednesday, August 21, 2019 11:12 PM
> To: postgis-users at lists.osgeo.org
> Subject: Re: [postgis-users] netcdf files deprecated in raster2pgsql?
> Hi all,
> I recently discovered that my new version of raster2pgsql doesn't work for
> importing netcdf files, but an older version I have on my computer does.
> I'm wondering if netcdf handling has been dropped/deprecated in the later
> version.
> With postgresql version 11.0 and postgis 2.5, this fails:
> raster2pgsql -s 4326 -c -F -t 256x256 NETCDF:"[myfile]":p mytable | psql
> -h localhost -U [user] -d [database]
> ...but this works with an older version of raster2pgsql that came with
> PostgreSQL 9.4:
> /usr/local/old_pgsql-9.4/bin/raster2pgsql -s 4326 -c -F -t 256x256
> NETCDF:"[myfile]":p mytable | psql -h localhost -U [user] -d [database]
> I also note that "netcdf" is not included in the list of formats returned
> by 'raster2pgsql -G' with the new version.
> Thanks,
> John
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190826/8871d4f8/attachment.html>
