[postgis-users] totopogeom resulting in SQL/MM Spatial exception
Bo Guo
bo.guo at gisticinc.com
Wed Jan 16 08:40:02 PST 2019
strk,
I changed from 0.001 to 0.00001 and had the similar error. When I leave
out he tolerance value all together, I got the following msg:
ERROR: SQL/MM Spatial exception - geometry crosses edge 571239
CONTEXT: PL/pgSQL function totopogeom(geometry,topogeometry,double
precision) line 112 at FOR over SELECT rows PL/pgSQL function
totopogeom(geometry,character varying,integer,double precision) line
88 at assignment SQL state: XX000
I will try to break the update into multiple batches
Bo
On 1/16/19 9:14 AM, Sandro Santilli wrote:
> On Tue, Jan 15, 2019 at 09:48:30AM -0700, Bo Guo wrote:
>> UPDATE azgiv.roadcenterlines SET grd_topo_geom =
>> topology.totopogeom(grd_geom, 'azgiv_topo', l_topo_layer_id, l_tolerance);
>> I am getting the following error similar to below:
>> ERROR: SQL/MM Spatial exception - geometry crosses edge 566760 CONTEXT:
>> PL/pgSQL function totopogeom(geometry,topogeometry,double precision)
>> Wonder if someone could shed some light as to what I need to look for?
> I suggest you try with a smaller tolerance for a start. Variations to
> tolerance can help in both directions too. Also try to converting to
> TopoGeometry in chunks rather than all at once, so you can take the
> chance to clean up small faces between runs.
> PS: toTopoGeom _does_ split existing edges
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Bo Guo, PhD, PE
Gistic Research, Inc.
2033 E Warner Rd. Ste 105
Tempe, AZ 85284
www.gisticinc.com
Tel: 480-656-9962
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190116/d8d571e0/attachment.html>
