[postgis-users] breake lines
Andrea Peri
aperi2007 at gmail.com
Tue Sep 3 10:21:58 PDT 2019
I will a chance trying to use the ST_Node.
A.
Il mar 3 set 2019, 19:18 Martin Davis <mtnclimb at gmail.com> ha scritto:
> Have you tried using ST_Split passing each input line and for the second
> argument a MultiLineString comprised of all lines that it might intersect
> (obtained via BBOX or ST_Intersects query)? It seems like that should not
> create any duplicate linework from the input line.
> As far as I know there's no other way to do this using current PostGIS
> functions. It's an interesting requirement - it sounds like essentially
> you want to node one layer against another. There's actually the machinery
> to do this internally in PostGIS/GEOS, but it's never come up as a
> requirement before, so has not been exposed as a function.
> What is your use case?
> On Tue, Sep 3, 2019 at 9:48 AM <paul.malm at lfv.se> wrote:
>> If I split lines with another line layer, I will get a lot of duplicaded
>> line segments since the lines could be intersected several times. It is not
>> possible to use update on the table when splitting one geomety to two.
>> I think it must be possible, but I’m not that skilled in SQL and I’ve not
>> found any examples on the net.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190903/b39acdc6/attachment.html>
