[postgis-users] Relationship between PostGIS, Azure and its various components
Shaozhong SHI
shishaozhong at gmail.com
Tue Sep 8 14:23:46 PDT 2020
On Tue, 8 Sep 2020 at 20:49, Regina Obe <lr at pcorp.us> wrote:
> Shao,
> Not sure the question you are asking. Hopefully this helps
> There are 2 kinds of Azure that PostGIS can exist in
> Azure Database for PostgreSQL -- PostGIS is an offered extension --
> Database as a Service
> Azure Server – you can spin up a server like Ubuntu on Azure
> infrastructure and install your own PostgreSQL and PostGIS.
> If you go with DbaaS I think it’s much more expensive than just an Azure
> Server, but you get stuff like simpler scalability and mirroring. Aside
> from expense you are stuck with whatever version of PostGIS they give you
> and have limited extension offerings.
> Azure Server – cheaper more freedom to install the version of PostgreSQL
> and PostGIS you want as well as much more freed of installing extensions
> and accessing the network.
> --This same statement can be said about Amazon or Google offerings.
Hi, Regina Obe,
Thank you.
Some enterprises/organisations are implementing Azure, and get data at one
place.
My gut feeling is that a lot of these components on Azure may not be able
to offer what PostgreSQL/PostGIS can offer. I am trying to see how best
PostgreSQL/PostGIS can play an important role on the Azure and interplay
and interoperate with other components.
Obviously, many organisations have a wide range of types of data. I would
like to see that PostgreSQL/PostGIS can play an important role on the Azure.
We must have some strong and factual points in hand to persuade others. It
is along this line that I am thinking.
Regards,
Shao
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Shaozhong SHI
> *Sent:* Tuesday, September 8, 2020 1:58 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* [postgis-users] Relationship between PostGIS, Azure and its
> various components
> Rapid ICT transformation has led to the situation where PostGIS has to
> exist with Azure and its various components. A clear understanding of the
> interplay of PostGIS and Azure and its components is of interest.
> Anyone has got experience and insight to share?
> Regards,
> Shao
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200908/1c650b7e/attachment.html>
