[postgis-users] Various ways to handle addresses in postgresql
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Sat Jan 9 01:41:46 PST 2021
Hello,
People make neural networks for this kind of task:
https://github.com/openvenues/libpostal
сб, 9 сту 2021, 12:40 карыстальнік Shaozhong SHI <shishaozhong at gmail.com>
напісаў:
> Hi, Steve W,
> it is easy to parse addresses as tokens. But it is difficult to put
> tokens in right columns, due to that the same address could be expressed
> with partial address or full address.
> The same address can be written like, Flat 1 122 Great Avenue London UK,
> or Flat 1 122 Greet Avenue Central London London United Kingdom.
> When this happens, each address has different number of tokens, so
> different numbers of tokens. Is there a way to deal with this issue so
> that each token can get into right column?
> Please enlighten me.
> Regards,
> David
> On Sat, 25 Apr 2020 at 05:09, Stephen Woodbridge <
> stephenwoodbridge37 at gmail.com> wrote:
>> And I have create an address-standardizer project here
>> https://github.com/woodbri/address-standardizer which is user
>> configurable. I might be over kill is you just want to strip off the
>> number, in which case you might just use a SQL regexp replace to remove
>> it.
>> -Steve W
>> On 4/25/2020 12:04 AM, Stephen Woodbridge wrote:
>> > PostGIS has address_standardizer extension that includes
>> > parse_address() and standardize_address() functions.
>> > -Steve W
>> >> maybe you can use the https://github.com/openvenues/libpostal library
>> >> with your favorite language bindings ( Python / Ruby / Go / PHP /
>> >> Node / R / Java ...)
>> >> or as a Postgres database extension:
>> https://info.crunchydata.com/blog/quick-and-dirty-address-matching-with-libpostal
>> >> https://github.com/pramsey/pgsql-postal
>> >> Regards,
>> >> Imre
>> >> <mailto:shishaozhong at gmail.com>> ezt írta (időpont: 2020. ápr. 25.,
>> >> Szo, 2:49):
>> >> I find this is a simple, but important question.
>> >> How best to split numbers and the rest of address?
>> >> For instance, one tricky one is as follows:
>> >> 21-1 Great Avenue, a city, a country, this planet
>> >> How to turn this into the following:
>> >> column 1, column 2
>> >> Note: there is a hyphen in 21-1
>> >> Any clue?
>> >> Regards,
>> >> Shao
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> postgis-users at lists.osgeo.org <mailto:
>> postgis-users at lists.osgeo.org>
>> >> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210109/ccafa965/attachment.html>
