[postgis-users] Various ways to handle addresses in postgresql
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Sat Jan 9 07:00:31 PST 2021
David,
Yup and this is just one a dozens of cases that you have to deal with. You are dealing with a natural language processing problem. And you have to deal with human input that has typos and abbreviations.
These issues are what the address standardizer fixes. It tokenized the address and uses the gazette to standardize the terms and then classifies each term and assigns it to part of the address based on a grammar.
So there is a simple solution, use my address standardizer, it is free, MIT license, it has a sample lexicon/ gazette and grammar for the UK, it is easy to modify these to fit your needs, and it just works. Oh if you want to do another county it also has sample files for 25 countries.
Sent from my iPhone
> On Jan 9, 2021, at 4:42 AM, Darafei Komяpa Praliaskouski <me at komzpa.net> wrote:
> Hello,
> People make neural networks for this kind of task:
> https://github.com/openvenues/libpostal
> сб, 9 сту 2021, 12:40 карыстальнік Shaozhong SHI <shishaozhong at gmail.com> напісаў:
>> Hi, Steve W,
>> it is easy to parse addresses as tokens. But it is difficult to put tokens in right columns, due to that the same address could be expressed with partial address or full address.
>> The same address can be written like, Flat 1 122 Great Avenue London UK, or Flat 1 122 Greet Avenue Central London London United Kingdom.
>> When this happens, each address has different number of tokens, so different numbers of tokens. Is there a way to deal with this issue so that each token can get into right column?
>> Please enlighten me.
>> Regards,
>> David
>>> On Sat, 25 Apr 2020 at 05:09, Stephen Woodbridge <stephenwoodbridge37 at gmail.com> wrote:
>>> And I have create an address-standardizer project here
>>> https://github.com/woodbri/address-standardizer which is user
>>> configurable. I might be over kill is you just want to strip off the
>>> number, in which case you might just use a SQL regexp replace to remove it.
>>> -Steve W
>>> On 4/25/2020 12:04 AM, Stephen Woodbridge wrote:
>>> > PostGIS has address_standardizer extension that includes
>>> > parse_address() and standardize_address() functions.
>>> > -Steve W
>>> >> maybe you can use the https://github.com/openvenues/libpostal library
>>> >> with your favorite language bindings ( Python / Ruby / Go / PHP /
>>> >> Node / R / Java ...)
>>> >> or as a Postgres database extension:
>>> >> https://info.crunchydata.com/blog/quick-and-dirty-address-matching-with-libpostal
>>> >> https://github.com/pramsey/pgsql-postal
>>> >> Regards,
>>> >> Imre
>>> >> <mailto:shishaozhong at gmail.com>> ezt írta (időpont: 2020. ápr. 25.,
>>> >> Szo, 2:49):
>>> >> I find this is a simple, but important question.
>>> >> How best to split numbers and the rest of address?
>>> >> For instance, one tricky one is as follows:
>>> >> 21-1 Great Avenue, a city, a country, this planet
>>> >> How to turn this into the following:
>>> >> column 1, column 2
>>> >> Note: there is a hyphen in 21-1
>>> >> Any clue?
>>> >> Regards,
>>> >> Shao
>>> >> _______________________________________________
>>> >> postgis-users mailing list
>>> >> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>>> >> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210109/0e99638c/attachment.html>
