[postgis-users] Postgis 2.4 Error: undefined symbol: proj_crs_get_datum_ensemble
Jakub Wartak
Jakub.Wartak at tomtom.com
Tue Jul 6 06:37:10 PDT 2021
> # SELECT postgis_full_version() ;
> ERROR: could not load library "/usr/pgsql-9.6/lib/rtpostgis-2.4.so":
> /usr/gdal32/lib/libgdal.so.28: undefined symbol: proj_crs_get_datum_ensemble
> CONTEXT: SQL statement "SELECT public.postgis_gdal_version()"
> PL/pgSQL function postgis_full_version() line 33 at SQL statement
> /usr/gdal32/lib/libgdal.so.28 | grep proj
> libproj.so.19 => /usr/proj71/lib/libproj.so.19 (0x00007fb368a4f000)
> /usr/proj71/lib/libproj.so.19.1.1
> /usr/proj72/lib/libproj.so.19
> /usr/proj72/lib/libproj.so.19.2.1
> $ rpm -qa | grep proj
> proj71-7.1.1-3.rhel7.x86_64
> proj-4.8.0-4.el7.x86_64
> proj72-7.2.1-1.rhel7.x86_64
GDAL wants 'libproj.so.19' , but you have two of them installed which might confuse ld.so. Maybe try to verify - using nm(1), readelf -s (1) or objdump (1)- which of the libproj.so.19 has "proj_crs_get_datum_ensemble" function exported and then uninstall the opposite one (so uninstall proj71 as it might confuse the dynamic loader, so that it switches to proj72?). Example:
[XXXXXXXXXXXXXXXXX ~]$ readelf --wide -s /usr/proj72/lib/libproj.so.19 | grep proj_crs_get_datum
1420: 00000000001d2c20 725 FUNC GLOBAL DEFAULT 11 proj_crs_get_datum_forced
2287: 00000000001d5270 428 FUNC GLOBAL DEFAULT 11 proj_crs_get_datum_ensemble
2477: 00000000001d2a70 428 FUNC GLOBAL DEFAULT 11 proj_crs_get_datum
Also you may want to play with ldconfig.
-J.
