[postgis-users] [Extern] Re: Postgis 2.4 Error: undefined symbol: proj_crs_get_datum_ensemble
Zwettler Markus (OIZ) Markus.Zwettler at zuerich.ch
Tue Jul 6 07:33:24 PDT 2021
proj71-7.1.1-3.rhel7.x86_64 didn't contain the function.
Everything is fine now after I deinstalled it.
Thanks a lot,
Markus
> -----Ursprüngliche Nachricht-----
> Von: postgis-users <postgis-users-bounces at lists.osgeo.org> Im Auftrag von
> Jakub Wartak
> Gesendet: Dienstag, 6. Juli 2021 15:37
> An: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Betreff: [Extern] Re: [postgis-users] Postgis 2.4 Error: undefined symbol:
> Hi,
> > # SELECT postgis_full_version() ;
> > ERROR:  could not load library "/usr/pgsql-9.6/lib/rtpostgis-2.4.so":
> > /usr/gdal32/lib/libgdal.so.28: undefined symbol:
> > CONTEXT:  SQL statement "SELECT public.postgis_gdal_version()"
> > PL/pgSQL function postgis_full_version() line 33 at SQL statement [..]
> > /usr/gdal32/lib/libgdal.so.28 | grep proj
> >         libproj.so.19 => /usr/proj71/lib/libproj.so.19
> > (0x00007fb368a4f000) [..]
> > /usr/proj71/lib/libproj.so.19.1.1
> > /usr/proj72/lib/libproj.so.19
> > /usr/proj72/lib/libproj.so.19.2.1
> > $ rpm -qa | grep proj
> > proj-4.8.0-4.el7.x86_64
> > proj72-7.2.1-1.rhel7.x86_64
> GDAL wants 'libproj.so.19' , but you have two of them installed which might
> confuse ld.so. Maybe try to verify - using nm(1), readelf -s (1) or objdump (1)-
> which of the libproj.so.19 has "proj_crs_get_datum_ensemble" function exported
> and then uninstall the opposite one (so uninstall proj71 as it might confuse the
> dynamic loader, so that it switches to proj72?). Example:
> [XXXXXXXXXXXXXXXXX ~]$ readelf --wide -s /usr/proj72/lib/libproj.so.19 | grep
> proj_crs_get_datum
>   1420: 00000000001d2c20   725 FUNC    GLOBAL DEFAULT   11
> proj_crs_get_datum_forced
>   2287: 00000000001d5270   428 FUNC    GLOBAL DEFAULT   11
>   2477: 00000000001d2a70   428 FUNC    GLOBAL DEFAULT   11
> proj_crs_get_datum
> Also you may want to play with ldconfig.
> -J.
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Achtung: Diese E-Mail wurde von einer externen Adresse verschickt. Klicken Sie
> auf keine Links und öffnen Sie keine angehängten Dateien, wenn Sie den Absender
> bzw. die Absenderin nicht kennen. Sind Sie sich unsicher, kontaktieren Sie den
> Service Desk der Stadt Zürich.
