[postgis-users] Geometries returning zero area with PostGIS 3.1.2.
Marco Boeringa
marco at boeringa.demon.nl
Sun Jul 11 03:42:04 PDT 2021
Hi all,
I am running into an issue with two of OpenStreetMap's polygon geomtries
returning a zero area for the following PostGIS SQL clause:
ST_Area(ST_ConvexHull(ST_Transform(way,4326))::geography,true)
Note that the data was imported using osm2pgsql, with the data stored in
WGS1984, not Web Mercator.
The two relations that cause the issue are:
https://www.openstreetmap.org/relation/2186646
<https://www.openstreetmap.org/relation/2186646>
https://www.openstreetmap.org/relation/3394113
One represents "Antarctica", the other the "Ross Dependency".
Note that both relations appear to be quite old (years), and I am
therefor pretty sure I have processed the exact same geometries
previously without issues with older versions of PostGIS after planet
import. Note also that both geometries test as valid with
"ST_Isvalid(way)" after import using osm2pgsql.
Has something changed in the latest PostGIS 3.1.2 that might explain
this result, e.g. especially related to the "::geography" cast or the
"ST_ConvexHull" statement?
Of course, in the way these geometries wrap the globe, they may
represent a challenge, but as said, I am pretty sure I must have
processed the same geometries without issues in previous releases of
PostGIS.
Marco
