[postgis-users] polygons inside polygon
Jorge Gustavo Rocha
jgr at di.uminho.pt
Tue Nov 30 03:44:09 PST 2021
Hi Paul,
Maybe you can try to apply a ST_ConvexHull. The resulting geometry
ST_touches the most outer polygon. Can you try that or this not make sense?
Regards,
Jorge
On 30/11/21 10:42, paul.malm at lfv.se wrote:
> Thank you Marcin!
> I’m not sure if I understand you correct. Here is what I tried to do to
> get the outer most polygons:
> Select * from "org" Where "fid" IN(
> select distinct on (t1.fid) t1.fid
> from "org" t1,"org" t2
> where ST_Area(t1.the_geom)>ST_Area(t2.the_geom)
> and ST_intersects(t1.the_geom,t2.the_geom)
> order by t1.fid,ST_Area(t2.the_geom) desc)
> AND "fid" NOT IN (
> select distinct on (t1.fid) t2.fid
> and ST_Intersects(t1.the_geom,t2.the_geom)
> order by t1.fid,ST_Area(t2.the_geom) desc);
> I’m still getting polygons inside other polygons.
> Kind regards,
> Paul
> *Från:*postgis-users <postgis-users-bounces at lists.osgeo.org> *För
> *Marcin Mionskowski
> *Skickat:* den 30 november 2021 08:40
> *Till:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Ämne:* Re: [postgis-users] polygons inside polygon
> *Klicka bara på länkar och öppna bilagor om du litar på avsändaren och
> vet att innehållet är säkert.*
> Assuming (1) your problem is not trivial (you have more then one "outer
> most" polygon) and (2) there can be only one type of spatial
> relationship (polygons are properly contained
> https://postgis.net/docs/ST_ContainsProperly.html
> <https://url11b.mailanyone.net/v1/?m=1mrxkX-0008NY-3a&i=57e1b682&c=E3fbWP_UxOp_aLqY_yLoWpoHnd9en_osfYJj-MVUi5KueBYHM1BjtHCJY7dzm-LB011qRSoveVUqU8Wbo-SQYSOYr9IMVYP063lEVQCr3G9ErfMMDLx0JWLLcyDsdbz4OsKdCpzFuBZU-g6Zf2gdwauTuWm-WmCCd-yXe9BTojKOCWOHXliBKmmUzJm2IMYt21G3fa06qgsJNMVB57og9hfef8SNtdDMCfyM41WFZcL6sAWT7ulje7X4_yE-ywIBR2t6-OHWw7iVq5THHQ_FPz6JAbbD-P0i4FQ6Ze6X30U>)
> below is my take on this:
> select distinct on (t1.id
> <https://url11b.mailanyone.net/v1/?m=1mrxkX-0008NY-3a&i=57e1b682&c=9KJuH3f7Mex6ks3lu5cPQvny5O6XFhyh-eH6svguvEFAWIQVxt2r_IF0pHeMBwTmQ0XE2xxmCMWnaDbfaMp5XAI5b_Dcd0CClUb5RGp_7jG34xScneDpX0vYGQ4vngdzDwWvGm-5Vrd9D1J_a38Rof5Lup9vwpMo_mGHYNGYu4f1wTbn36eA3P8CNM6_0ioVin4dzKvW5LcIMv9Lun1VjfK4qpwRVaVWuelYCEa3WiGmNGu1zEEv9fA7t7zcNFT0>)
> t1.id
> <https://url11b.mailanyone.net/v1/?m=1mrxkX-0008NY-3a&i=57e1b682&c=9KJuH3f7Mex6ks3lu5cPQvny5O6XFhyh-eH6svguvEFAWIQVxt2r_IF0pHeMBwTmQ0XE2xxmCMWnaDbfaMp5XAI5b_Dcd0CClUb5RGp_7jG34xScneDpX0vYGQ4vngdzDwWvGm-5Vrd9D1J_a38Rof5Lup9vwpMo_mGHYNGYu4f1wTbn36eA3P8CNM6_0ioVin4dzKvW5LcIMv9Lun1VjfK4qpwRVaVWuelYCEa3WiGmNGu1zEEv9fA7t7zcNFT0>,t2.id
> <https://url11b.mailanyone.net/v1/?m=1mrxkX-0008NY-3a&i=57e1b682&c=MB1btGDh1LRWWz9_qH-7fMRyiv5SylMmhNclzuXCnly7_WjBFSzNNi8uoxskAeJ4w4vgf__otNnIlUBwzIcTXhXbUpsTFsuilzyfmYd9zwlz05eB_sxpFqejtXwlOFEeYlEQLMRezJUhez4-Az3YSqWptDxKMQo3xICyLgQ_J7X-Y60pOXOjXiF2bxqaDL7qbXenH7LOd0rsTK8ovDtTM0OQ4EBcMuXDxIvRB7k1Wb5YS5ejXpy-7iOFHBuUUIEB>
> from t t1,t t2
> where ST_Area(t1.geom)>ST_Area(t2.geom)
> and ST_Intersects(t1.geom,t2.geom)
> order by t1.id
> <https://url11b.mailanyone.net/v1/?m=1mrxkX-0008NY-3a&i=57e1b682&c=9KJuH3f7Mex6ks3lu5cPQvny5O6XFhyh-eH6svguvEFAWIQVxt2r_IF0pHeMBwTmQ0XE2xxmCMWnaDbfaMp5XAI5b_Dcd0CClUb5RGp_7jG34xScneDpX0vYGQ4vngdzDwWvGm-5Vrd9D1J_a38Rof5Lup9vwpMo_mGHYNGYu4f1wTbn36eA3P8CNM6_0ioVin4dzKvW5LcIMv9Lun1VjfK4qpwRVaVWuelYCEa3WiGmNGu1zEEv9fA7t7zcNFT0>,ST_Area(t2.geom)
> desc;
> Enclose this in CTE and then just select "outer" polygons based on left
> column and "inner" based on right column.
> wt., 30 lis 2021 o 07:30 <paul.malm at lfv.se <mailto:paul.malm at lfv.se>>
> napisał(a):
> Hi,
> I have a polygon layer where polygons are inside other polygons
> (could be polygons in polygons in polygons…).
> I would like to separate them in 2 different layers, one layer with
> the outer most polygon and one layer with all polygons that has a
> surrounding polygon.
> Is there a smart way to do this in SQL?
> Thanks,
> Paul
> 1_LFV_svensk_96
> Paul Malm
> Operations / AIM Flyginfo SE
> Direkt 08-797 70 23 Mobil 070-860 11 15
> Besöks- och postadress
> LFV Flyginfo SE
> Af Pontins väg 6
> 115 21 STOCKHOLM
> Tänk på miljön innan du skriver ut detta e-postmeddelande.
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> <https://url11b.mailanyone.net/v1/?m=1mrxkX-0008NY-3a&i=57e1b682&c=_uxAORlsjsjbGN7PYxaRnlHKfS3HxcXJKlgGb8oZkkQQ7KeYaBvj63dVA9iAwHJFsiNVtticrWS07KEdiJM7B5FK1Yaq43by7MzodRIkmRm9i5TYx5AMTzK7gTO_Qito-2qIlo3A7Ie0mipOiHVt2vWc3OvcW4JCOK1neLV9mQTj4o8JyaGnGIG3M_sLpXMopSV6-fN3Qc5DR2cPPfCZ4ySDLNEacKWQP5buUcMtkzhGviuZh24fRX4mSjaR9t7d9eZEeB6bPE0YFX2AgKUEY2w9g5s3z41MQ6FNL6ZvrJU>
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
