[postgis-users] How to generate a map grid given a GeoHash?
Regina Obe lr at pcorp.us
Fri Dec 16 08:35:01 PST 2022
Not sure what you are looking for here, but I suspect the answer is no.  You wouldn’t get a grid. More like a set of nested squares. Geohash is not of much use except possibly for very very small grids. Even then it’s not that great.
Maybe you can read this to get some ideas
https://en.wikipedia.org/wiki/Geohash
For example this grid many of the tiles have the same geohash:
SELECT i, j, geom , ST_GeoHash(geom) AS geohash
FROM ST_SquareGrid(0.5, ST_MakeEnvelope(-78,38,-77, 39, 4326))
ORDER BY geohash;
You could compute a bounding box from a GeoHash with https://postgis.net/docs/ST_GeomFromGeoHash.html
So if I take the above and compute a bounding box based on distinct GeoHash
SELECT DISTINCT ST_GeoHash(geom) AS geohash, ST_GeomFromGeoHash(ST_GeoHash(geom)) AS geom
ORDER BY geohash;
I would get a result that looks like this
If you pick a smaller tile size such as:
SELECT DISTINCT ST_GeoHash(geom) AS geohash, ST_SetSRID(ST_GeomFromGeoHash(ST_GeoHash(geom)),4326) AS geom
FROM ST_SquareGrid(0.005, ST_MakeEnvelope(-78,38,-77, 39, 4326))
ORDER BY geohash;
The story is better, but still not something you can count on for gridding.  So you were right the first time you asked about there being more to it than bounding box, the shorter than bounding box hash doesn’t necessarily mean the bounding box you generated from is bigger than another bounding box located elsewhere that has a longer hash.  Also depends on position on the earth.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Shaozhong SHI
Sent: Friday, December 16, 2022 8:39 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: [postgis-users] How to generate a map grid given a GeoHash?
Can a map grid be worked out or generated given a Geohash?
Regards,
David
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221216/7238554b/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221216/7238554b/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221216/7238554b/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221216/7238554b/attachment-0002.png>
