[postgis-users] How to generate a map grid given a GeoHash?
Denis Rykov rykovd at gmail.com
Fri Dec 16 10:29:31 PST 2022
Thank you Regina for your detailed answer! Let me jump-in.
> For example this grid many of the tiles have the same geohash
That is correct, but can't it be solved just by specifying a proper geohash
level, like:
postgres=# select i, j, ST_GeoHash(geom, 4) from ST_SquareGrid(0.5,
ST_MakeEnvelope(-78,38,-77, 39, 4326));
  i   | j  | st_geohash
 -156 | 76 | dqb9
 -156 | 77 | dqbs
 -156 | 78 | dqbx
 -155 | 76 | dqc1
 -155 | 77 | dqch
 -155 | 78 | dqcp
 -154 | 76 | dqc3
 -154 | 77 | dqck
 -154 | 78 | dqcr
(9 rows)
On Fri, Dec 16, 2022 at 5:58 PM Regina Obe <lr at pcorp.us> wrote:
> Not sure what you are looking for here, but I suspect the answer is no.
> You wouldn’t get a grid. More like a set of nested squares. Geohash is not
> of much use except possibly for very very small grids. Even then it’s not
> that great.
> Maybe you can read this to get some ideas
> https://en.wikipedia.org/wiki/Geohash
> For example this grid many of the tiles have the same geohash:
> SELECT i, j, geom , ST_GeoHash(geom) AS geohash
> FROM ST_SquareGrid(0.5, ST_MakeEnvelope(-78,38,-77, 39, 4326))
> ORDER BY geohash;
> You could compute a bounding box from a GeoHash with
> https://postgis.net/docs/ST_GeomFromGeoHash.html
> So if I take the above and compute a bounding box based on distinct
> GeoHash
> SELECT DISTINCT ST_GeoHash(geom) AS geohash,
> ST_GeomFromGeoHash(ST_GeoHash(geom)) AS geom
> ORDER BY geohash;
> I would get a result that looks like this
> If you pick a smaller tile size such as:
> ST_SetSRID(ST_GeomFromGeoHash(ST_GeoHash(geom)),4326) AS geom
> FROM ST_SquareGrid(0.005, ST_MakeEnvelope(-78,38,-77, 39, 4326))
> ORDER BY geohash;
> The story is better, but still not something you can count on for
> gridding.  So you were right the first time you asked about there being
> more to it than bounding box, the shorter than bounding box hash doesn’t
> necessarily mean the bounding box you generated from is bigger than another
> bounding box located elsewhere that has a longer hash.  Also depends on
> position on the earth.
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Shaozhong SHI
> *Sent:* Friday, December 16, 2022 8:39 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* [postgis-users] How to generate a map grid given a GeoHash?
> Can a map grid be worked out or generated given a Geohash?
> Regards,
> David
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221216/5d2c197f/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221216/5d2c197f/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221216/5d2c197f/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221216/5d2c197f/attachment-0002.png>
