[postgis-users] Help optimizing query
Luca Bertoncello
lucabert at lucabert.de
Wed Dec 21 02:39:31 PST 2022
Hi all!
I have a table "elevation", defined as:
gis=# \d+ elevation
Table "public.elevation"
Column | Type | Collation | Nullable | Default | Storage
| Stats target | Description
latlng | geography | | | | main
lat | double precision | | | | plain
lng | double precision | | | | plain
elevation | real | | | | plain
Hier I saved data about elevation of the terrain...
It works and I can use the data, but this is very slow if I'd like to
get the elevation graph of a path...
Currently I use this function:
CREATE OR REPLACE FUNCTION getElevationsOnLine(startPoint geometry,
endPoint geometry, pointsInterval int)
RETURNS TABLE (
lat DOUBLE PRECISION,
lng DOUBLE PRECISION,
elevation REAL,
dist DOUBLE PRECISION
LANGUAGE plpgsql
AS $$
DECLARE
point geometry;
BEGIN
FOR point IN
SELECT (ST_DumpPoints(ST_Segmentize(ST_MakeLine(startPoint,
endPoint)::geography, pointsInterval)::geometry)).geom
LOOP
RETURN QUERY
SELECT elevation.lat, elevation.lng, elevation.elevation,
elevation.latlng <-> point AS dist
FROM elevation
ORDER BY dist LIMIT 1;
END LOOP;
END;
The problem is the SELECT elevation.... query.
Using explain analyze I see:
QUERY
PLAN
Limit (cost=165202.56..165202.68 rows=1 width=28) (actual
time=2939.661..2946.685 rows=1 loops=1)
-> Gather Merge (cost=165202.56..297446.23 rows=1133438 width=28)
(actual time=2939.658..2946.680 rows=1 loops=1)
Workers Planned: 2
Workers Launched: 2
-> Sort (cost=164202.54..165619.33 rows=566719 width=28)
(actual time=2828.064..2828.066 rows=1 loops=3)
Sort Key: ((latlng <->
'0101000020E6100000E17A14AE47412C40BC74931804A64940'::geography))
Sort Method: top-N heapsort Memory: 25kB
Worker 0: Sort Method: top-N heapsort Memory: 25kB
Worker 1: Sort Method: top-N heapsort Memory: 25kB
-> Parallel Seq Scan on elevation (cost=0.00..161368.94
rows=566719 width=28) (actual time=3.910..2415.377 rows=453375 loops=3)
Planning Time: 0.199 ms
Execution Time: 2946.763 ms
the given coordinate is just to check...
I already tried to define an index over latlng, but it does not help.
Can someone help me to speed up the query?
Thanks a lot
Luca Bertoncello
(lucabert at lucabert.de)
