[postgis-users] error: Directed line merging requires GEOS-3.11 or higher
Karsten Tebling tebling at masuch.de
Wed Dec 21 06:08:29 PST 2022
Hello Regina,
thanks to your information I could find a workaround. I ended up
removing the postgresql and ubuntugis-unstable repositories along with
the installed software and installed docker to use the alpine-based
docker files (https://registry.hub.docker.com/r/postgis/postgis/). The
restore was successful and everything seems to be working so far.
Thanks for the help!
Am 20.12.2022 um 18:02 schrieb Regina Obe:
> If you have ubuntugis-unstableinstalled too, it’s quite possible that
> your GEOS is coming from ubuntugis unstable
> and your postgis is coming from apt.postgresql.org. Even worse as I
> recall, I think ubuntugis relegates compiling of postgis upstream
> (main repo), so you might still end up with a PostGIS compiled with a
> lower version.
> apt.postgresql.org builds against whatever the base repo is of
> Ubuntu/Debian etc.  Last I checked, all stable releases (at least for
> Ubuntu) I could get put you at GEOS 3.10.  So I suspect your Mint
> postgis was at best compiled with GEOS 3.10.
> Unfortunately the GEOS is checked at compile time for enabling
> features, not runtime, but our full version exposes
> the runtime that is being used, which for most cases is useful, except
> for the case where new features are disabled.
> Sandro and Paul, is there any way we can expose the compiled version
> of GEOS and Proj?
> This isn’t the first time someone has been confused by this issue and
> it’s been even worse with Proj (around those times when the proj.db
> changed)
> I think I asked before but I forget what you two answered.
> Thanks,
> Regina
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Karsten Tebling
> *Sent:* Tuesday, December 20, 2022 6:07 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* [postgis-users] error: Directed line merging requires
> GEOS-3.11 or higher
> Hello,
> I'm trying to restore a backup from a windows installation to a new
> linux mint 21 installation but it always fails with "error: Directed
> line merging requires GEOS-3.11 or higher". According to the
> postgis_full_version both installations should support geos 3.11, but
> I do get the error anyway. I'm using pgadmin4-desktop (installed via
> apt https://www.pgadmin.org/download/pgadmin-4-apt/) to execute the
> queries.
> postgis_full_version:
>   * windows: POSTGIS="3.3.2 3.3.2" [EXTENSION] PGSQL="140"
>     GEOS="3.11.1-CAPI-1.17.1" PROJ="7.2.1" LIBXML="2.9.9"
>     LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"
>   * linux mint: POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150"
>     GEOS="3.11.1-CAPI-1.17.1" PROJ="8.2.1" LIBXML="2.9.13"
>     LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
> The linux mint is a fresh installation, I installed postgresql and
> postgis via PostgreSQL Apt Repository
> (https://www.postgresql.org/download/linux/ubuntu/), using the command:
>   * sudo apt install postgresql-15 postgis postgresql-15-postgis-3
> Another ppa I have in use is ubuntugis-unstable, it also includes
> postgis - could this be a reason for the problem?
> Help would be greatly appreciated.
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221221/fdd82882/attachment.htm>
