[postgis-users] Help shaping the future: how do you use spatial_ref_sys ?
Moen, Paul T.
pmoen at nd.gov
Fri Feb 4 11:15:53 PST 2022
No. Pasted wrong line. Here is one of our custom entries.
INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (900001, 'EPSG', 900001, '', '+proj=lcc +lat_1=47.48333333333333 +lat_2=46.18333333333333 +lat_0=45.66666666666666 +lon_0=-102.53 +x_0=599999.9999976 +y_0=0 +ellps=GRS80 +datum=NAD83 +to_meter=0.3048 +no_defs');
On 2/4/22, 1:10 PM, "postgis-users on behalf of Sandro Santilli" <postgis-users-bounces at lists.osgeo.org on behalf of strk at kbt.io> wrote:
***** CAUTION: This email originated from an outside source. Do not click links or open attachments unless you know they are safe. *****
On Fri, Feb 04, 2022 at 06:56:58PM +0000, Moen, Paul T. wrote:
> Sorry, we insert into the spatial_ref_sys table not the spatial_ref_sys.sql file.
> We assign the SRIDs starting at 900000. We have been setting the auth_name to 'EPSG' and the auth_srid to the same value as the srid.
> Example.
> INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (6933, 'EPSG', 6933, '', '+proj=cea +lon_0=-100.5 +lat_ts=47.5 +x_0=2000000 +y_0=0 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +to_meter=0.3048 +no_defs');
Is the above an actual custom entry of yours ?
Because the SRID is NOT higher than 900000 as you mentioned.
What version of libproj are you using ?
Are you aware that given a new enough libproj (>= 6.1)
the proj4text in your record might not be used at all ?
In the spatial_ref_sys.sql file in current PostGIS 3.3 the
EPSG/6933 entry has a different proj4text:
+proj=cea +lon_0=0 +lat_ts=30 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs
You said you also keep the entries installed by spatial_ref_sys.sql,
does it mean at the time you issued the above example INSERT your
PostGIS version did NOT include an entry for SRID=6933?
--strk;
> On 2/4/22, 12:04 PM, "postgis-users on behalf of Sandro Santilli" <postgis-users-bounces at lists.osgeo.org on behalf of strk at kbt.io> wrote:
> Thanks for answering Paul, more question inline
> On Fri, Feb 04, 2022 at 05:21:23PM +0000, Moen, Paul T. wrote:
> > We have 54 custom entries that we store in spatial_ref_sys.sql.
> Do you mean in the "spatial_ref_sys" PostgreSQL table or in the
> "spatial_ref_sys.sql" file ?
> How do you decide what SRIDs to assign to your custom entries ?
> What auth_name and auth_srid do you use ?
> >> - Do you also keep the entries installed by spatial_ref_sys.sql ?
> > Yes.
> >> - Do you ever update the table with entries from newer
> > No.
> Would you expect (or like) PostGIS upgrade to also upgrade
> thse system entries ?
> How do you upgrade PostGIS ?
> --strk;
postgis-users mailing list
postgis-users at lists.osgeo.org
https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fpostgis-users&data=04%7C01%7Cpmoen%40nd.gov%7C2bd1e57998464847281c08d9e81208d4%7C2dea0464da514a88bae2b3db94bc0c54%7C0%7C0%7C637795986424421139%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=E8Nrf%2F65QrX4H%2F0ZYw%2BNaIXj2zaCwgAhfSkJy53cA%2FA%3D&reserved=0
