[postgis-users] How to generate offset/parallel points from an existing points table?
Marcin Mionskowski
mionskowskimarcin at gmail.com
Fri Feb 11 01:35:33 PST 2022
I think ST_Translate is what you looking for
https://postgis.net/docs/ST_Translate.html
Greetings
pt., 11 lut 2022, 08:45 użytkownik Abhishek Pandey <
pandey.abhi3112 at gmail.com> napisał:
> Hi,
> I have a table with Lat Long and 3 additional values (X, Y, Z). What I
> want to do is plot the points and if additional Values are set as True,
> then generate a point Parallel to it or a point at an offset distance of
> 2.5 Meters for X, 5 meters for Y, and 7.5 Meters for Z. Here's a
> representation of the same.
> [image: image.png]
> I tried using this: [postgis-users] Create points along line (osgeo.org)
> <https://lists.osgeo.org/pipermail/postgis-users/2012-September/035109.html>
> But I am not sure how to do the same for points as I have just started
> learning PostGIS and SQL.
> thanks,
> Abhishek Pandey
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220211/c5493288/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220211/c5493288/attachment.png>
