[postgis-users] Inconsistent behavior with ST_Within across versions
Carsten Byrman
byrman+postgis at posteo.nl
Fri Feb 11 06:52:51 PST 2022
Thanks for your recommendations, Imre. I’ve updated my Trac ticket accordingly.
Kind regards, Carsten
> On 11 Feb 2022, at 13:46, Imre Samu <pella.samu at gmail.com> wrote:
> Hi Carsten,
> > but am just not sure I chose the appropriate milestone/component/version
> > Could you please give me some guidance here?
> ( I am a docker-postgis contributor)
> I am so sorry, but not "all" docker postgis/postgis image updating regularly ( with minor postgres,postgis) patches, bug fixes
> Only as in this repo: https://github.com/postgis/docker-postgis <https://github.com/postgis/docker-postgis> (scheduled on every Monday )
> You can check the "age / created " of the local docker image
> $ docker images postgis/postgis
> postgis/postgis 11-2.5-alpine 10c7c19a572c 4 days ago 330MB
> postgis/postgis 11-3.2-alpine 0303403af49f 4 days ago 369MB
> postgis/postgis 11-3.1-alpine f8c3965c17b8 7 weeks ago 328MB <-- too old
> postgis/postgis 11-3.0-alpine 4605eb1b2223 14 months ago 289MB <-- extreme old
> So I am not recommending the current -3.0; -3.1 docker images ( or any images older than 1 month, like "12-2.5-alpine" )
> This is a technical limitation of the current docker image workflow. ( probably it can be improved in the future )
> You can check the actual version with:
> SELECT version();
> SELECT PostGIS_Full_Version();
> The other important issue for debugging the alpine version ( 3.12 - 3.15 )
> and you can check with "cat /etc/os-release"
> $ docker run -t --rm postgis/postgis:11-3.0-alpine sh -c "cat /etc/os-release | grep VERSION"
> VERSION_ID=3.12.2
> $ docker run -t --rm postgis/postgis:11-3.2-alpine sh -c "cat /etc/os-release | grep VERSION"
> VERSION_ID=3.15.0
> So my recommendations:
> - please remove the "older docker" images from your test cases
> - and add postgres / postgis / alpine versions
> It is an interesting issue;
> Regards,
> Imre
> Carsten Byrman <byrman+postgis at posteo.nl <mailto:byrman%2Bpostgis at posteo.nl>> ezt írta (időpont: 2022. febr. 11., P, 7:41):
> Hello,
> I noticed inconsistent behavior with ST_Within across different PostgreSQL-PostGIS versions. Most notably, the outcome (not performance) of my query is determined by the presence of an index, which strikes me as odd. I filed my first bug report about 3 months ago and I expect no solution any time soon, but am just not sure I chose the appropriate milestone/component/version: https://trac.osgeo.org/postgis/ticket/5025 <https://trac.osgeo.org/postgis/ticket/5025>. Perhaps it’s not even a PostGIS but a PostgreSQL issue. Could you please give me some guidance here?
> Thanks, Carsten
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-users <https://lists.osgeo.org/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220211/1b1766fc/attachment.html>
