[postgis-users] Postgresql 14 bug?: "variable not found in subplan target list"
Marco Boeringa marco at boeringa.demon.nl
Sun Feb 13 14:31:11 PST 2022
Hi Imre,
Thanks very much for this information. I can wait, and will restore the
PostgreSQL 13 VM another time in the mean time to continue development
work. By the time 14.3 gets out, I'll have another look at a potential
PostgreSQL 14 upgrade.
Marco
Op 13-2-2022 om 23:08 schreef Imre Samu:
> Hi Marco,
> This is similar to your issue:
> https://www.postgresql.org/message-id/flat/4c347490-d734-5fdd-d613-1327601b4e7e%40mit.edu
>     /"With yesterday’s release of PostgreSQL 11.15, 12.10, and 13.6
>     (presumably 10.20 and 14.2 as well), Zulip’s test suite started
>     failing/
>     /with *“variable not found in subplan target list” errors* from
>     PostgreSQL on a table that has a PGroonga index.  I found the
>     following reproduction recipe from a fresh database:"/
> good news: probably it has been fixed;  commit: 2022Feb11:
> https://git.postgresql.org/gitweb/?p=postgresql.git&a=commitdiff&h=e5691cc9170bcd6c684715c2755d919c5a16fea2
> <https://git.postgresql.org/gitweb/?p=postgresql.git&a=commitdiff&h=e5691cc9170bcd6c684715c2755d919c5a16fea2>
> bad news:  need more than 3 months to the next minor release.  ( May
> 12th, 2022. )
> kind regards,
>  Imre
> Marco Boeringa <marco at boeringa.demon.nl> ezt írta (időpont: 2022.
> febr. 13., V, 22:32):
>     Hi Imre,
>     Thanks.
>     However, since I use the VM with PostgreSQL for development
>     exclusively, and am not to bothered re-importing OpenStreetMap
>     data, I actually decided to first delete all contents from the
>     databases I use for testing, as this leads to near instantaneous
>     upgrade, instead of needing to wait for an extended amount of time
>     for the upgrade to finish.
>     I then re-imported the data, so I am sure the data and indexes are
>     "fresh". I even went as far as dropping one the databases that
>     showed the issue, but was easily able to reproduce the issue with
>     my current workflow. Unfortunately, that is a whole bunch of
>     Python code generating SQL, and isn't easily compacted into a
>     simple test case. So it is a bit of digging around at first.
>     That said, your reference to a possible issue with the indexes, is
>     a possible lead to explore more.
>     I run PostgreSQL 14.2 by the way.
>     Marco
>     Op 13-2-2022 om 20:46 schreef Imre Samu:
>>     > after upgrading to PostgreSQL 14?
>>     > ... If I 'VACUUM (FULL)' the dataset, I get back the record
>>     count without issues.
>>     > ... Thoughts?
>>     imho:
>>     - Maybe the  'VACUUM (FULL)' is rebuilding your indexes - and
>>     solving some corrupted index problem?
>>     - As I see in 14.2 release notes:  "reindexing is recommended"
>>     https://www.postgresql.org/docs/release/14.2/
>>         /"However, some bugs have been found that may have resulted
>>         in corrupted indexes, as explained in the first two changelog
>>         entries. If any of those cases apply to you, *it's
>>         recommended to reindex possibly-affected indexes after
>>         updating.*"/
>>       in 14.1 - this is also recommended:
>>     https://www.postgresql.org/docs/14/release-14-1.html
>>     /          " it's recommended to reindex possibly-affected
>>     indexes after updating." /
>>     I don't know your upgrade process, but in this case, I will
>>     re-run the "reindexdb" utility
>>        ( https://www.postgresql.org/docs/14/app-reindexdb.html )
>>     Regards,
>>      Imre
>>     febr. 13., V, 18:35):
>>         Hi,
>>         Anyone else running into issues with their process flow after
>>         upgrading
>>         to PostgreSQL 14?
>>         After my failed attempt to update GEOS and PROJ, as I wrote
>>         about in
>>         recent posts, I restored my backup VM with plain vanilla
>>         PostgreSQL 13
>>         and PostGIS 3.2.0 from the official apt repository of
>>         PostgreSQL, which
>>         also includes GEOS 3.8.0 and PROJ 6.3.1.
>>         I then upgraded my cluster to PostgreSQL 14, without any
>>         other changes
>>         or upgrades.
>>         Now I am running into a weird issue and error I have never
>>         seen before
>>         in the past four years of working with PostgreSQL:
>>         - On a dataset that has undergone some basic processing in
>>         PostgreSQL /
>>         PostGIS, including things like 'ST_SimplifyVW', 'ST_Transform',
>>         somewhere along the processing chain I get a "variable not
>>         found in
>>         subplan target list" type error. This happens on a very basic
>>         SQL
>>         statement, just:
>>         "SELECT COUNT(*) FROM <TABLE>"
>>         - If I view the data in pgAdmin or DBeaver, I can open the
>>         table and
>>         view it spatially without issues. Running the same SQL COUNT
>>         statement
>>         against the dataset from these tools query interfaces, does
>>         give me the
>>         same error though as in my code.
>>         - If I 'VACUUM' the dataset, the error persists.
>>         - If I 'VACUUM (FULL)' the dataset, I get back the record
>>         count without
>>         issues.
>>         Thoughts?
>>         Marco
>>         _______________________________________________
>>         postgis-users mailing list
>>         postgis-users at lists.osgeo.org
>>         https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220213/e96d73c6/attachment.html>
