[postgis-users] Are there script examples for determine where vertices run clockwise or anti-clockwise?
Shaozhong SHI
shishaozhong at gmail.com
Wed Feb 16 23:31:43 PST 2022
How about each line gets split into segments. . Each segment is
constructed with two points (current and next points.
Then, calculate bearing/azimuth
Then, determine whether it is clockwise or counter-clockwise.
Can this be done?
Regards,
David
On Wed, 16 Feb 2022 at 20:39, Marcin Mionskowski <
mionskowskimarcin at gmail.com> wrote:
> It doesn't make sense for lines.
> Imagine LINESTRING(1 0,1 1) - which "part of a square" is this i.e. where
> is "the center of the square": (1) 0.5,0.5 or (2) 1.5,0.5?
> If (1) it's CCW, if (2) CW.
> śr., 16 lut 2022 o 21:29 Shaozhong SHI <shishaozhong at gmail.com>
> napisał(a):
>> The problem now is that I can not find anything for lines.
>> Anything like ST_IsPolygonCW|ST_IsPolygonCCW for lines for instance,
>> something like ST_IsLineCW|ST_IsLineCCW.
>> Regards,
>> David
>> On Wed, 16 Feb 2022 at 19:43, Marcin Mionskowski <
>>> Assuming simple polygons, composed from exterior ring only (i.e. no
>>> multipolygons), I think that you are looking for a function
>>> {ST_IsPolygonCW|ST_IsPolygonCCW}.
>>> Greetings,
>>> Marcin
>>> śr., 16 lut 2022 o 19:55 Imre Samu <pella.samu at gmail.com> napisał(a):
>>>> > how vertices run? clockwise or anti-clockwise?
>>>> maybe the:
>>>> https://postgis.net/docs/ST_Angle.html *"Computes the clockwise angle
>>>> between two vectors."*
>>>> or https://postgis.net/docs/ST_Azimuth.html
>>>> regards,
>>>> Imre
>>>> Shaozhong SHI <shishaozhong at gmail.com> ezt írta (időpont: 2022. febr.
>>>> 16., Sze, 17:06):
>>>>> Can we use PostGIS to find out how vertices run? clockwise or
>>>>> anti-clockwise?
>>>>> Regards,
>>>>> David
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220217/ff510281/attachment.html>
