[postgis-users] Clipping a raster and a polygon using ST_Intersection
liglio.pessoal at nexxa.com.br
Tue Nov 22 10:59:34 PST 2022
I created a retangular raster representing number of lightnings in a square.
So I have this matrix raster created using ST_MapAlgebraFct and
ST_MakeEmptyRaster.
This raster is not a tiled raster (tb_densitysurface), and when I Clip this
raster using a polygon, the query below, the performance is not good.
Maybe because the raster is not tiled. So how do I tile this raster ? And I
want the result to be a raster (not gval) to be exported as a file, and then
colored using GDAL.
It worked with a different query only using ST_Clip (this returns a rast
column and is very fast), but the edges aren´t smooth as using
ST_Insersection. I am using Postgis 2.5.
SELECT
(gval).val
(gval).geom
FROM (
SELECT ST_Intersection(
ST_Clip(rast,ST_Envelope(area_country)),
1,
area_country
) As gval
FROM country, tb_densitysurface WHERE ST_Intersects(rast, area_country)
and country.gid = 19
) As foo
Regards,
Liglio
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221122/70a24a6f/attachment.htm>
