[postgis-users] HOw to connect to Mapserver with an https protocol
karsten
karsten at terragis.net
Mon Sep 19 09:09:24 PDT 2022
Hi Mathias,
since this a question about MapServer (and HTTP/https protocols on a Server)
the MapServer user list <mailto:mapserver-users at lists.osgeo.org>
mapserver-users at lists.osgeo.org is a slightly better place for it (and not
this PostGIS list ).
Here some hints for you though:
The HTTP and HTTPS protocols are what a web server (server computer plus
HTTP Server software) enables - see
<https://fr.wikipedia.org/wiki/Hypertext_Transfer_Protocol>
It seems from your example URL that you are using Windows as an operating
system - what Web Server software are you using (MS IIS e.g. or Apache) ?
Overall you will need to configure whatever software you are using to serve
HTTP. In case of HTTPS (secure protocol
https://fr.wikipedia.org/wiki/HyperText_Transfer_Protocol_Secure ) you will
also need to obtain and use a SSL certificate. One good option for a free
one is Let's Encrypt see https://letsencrypt.org/
I hope this helps you to get started
Cheers
Karsten
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
Behalf Of mathias cunault
Sent: Monday, September 19, 2022 00:14
To: PostGIS Users Discussion
Subject: [postgis-users] HOw to connect to Mapserver with an https protocol
Using Mapserver 7.4, I render a WFS that is accessible with some regular URL
like "http://blabla.fr/cg-bin/mapserv.exe?MAP=..."
A user wants to use this WFS in another application web that needs a httpS
protocol.
I am not familiar with internet protocols so I don't know where to start :
is it a Mapserver configuration or a server (windows server R12)
configuration to setup ?
Thanks
Mathias Cunault
référent SIG / Admin Caviar
Inrap Tours - 148 av. Maginot
37000 TOURS
06 32 05 98 96
abonnez-vous à la lettre d'information de l'Inrap : http://ww
<http://www.inrap.fr/newsletter.php> w.inrap.fr/newsletter.php
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220919/fbf87a38/attachment.htm>
