[postgis-users] ERROR: transform: Point outside of projection domain (2050)
pham lan phamlankt at gmail.com
Mon Mar 27 13:41:22 PDT 2023
you are right, if i dropped the aforementioned index, analyze works
without  issue. As long as I tried to create the index again, it does not
let me creating the index but throw the same error.
But I wonder why it is working in the original database. What happened
during the backup/restore that changed this?
Btw, I see some small difference in the output of the original database.
May be it sounds something to you?
#This is the output from the original database
geodm=#  SELECT postgis_full_version();
 POSTGIS="2.5.5" [EXTENSION] PGSQL="100" GEOS="3.9.2-CAPI-1.14.3"
SFCGAL="1.3.1" PROJ="Rel. 7.2.1, January 1st, 2021" GDAL="GDAL 3.2.3,
released 2021/04/27" LIBXML="2.9.1" LIBJSON="0.11" LIBPROT
OBUF="1.0.2" (core procs from "2.5.2 r17328" need upgrade) TOPOLOGY
(topology procs from "2.5.2 r17328" need upgrade) RASTER (raster procs from
"2.5.2 r17328" need upgrade) (sfcgal procs from "2
(1 row)
On Mon, Mar 27, 2023 at 10:21 PM Regina Obe <lr at pcorp.us> wrote:
> Could be your ST_Transform index triggering the issue and you have at
> least one geometry out of bounds in there.
> I’d try dropping your geobordervtc_geom_25832_idx  and then rerunning
> analyze on the table.
> If that does fix it then try to gigure out which geometry is at fault.
> The 25632 is only good for utm zone 32N
> https://epsg.io/25832
> So I suspect you have a geometry way off from there causing the issue.
> Or it could be missing grid datum shift files at fault too.
> You can update your grid files by running at your command line:
> projsync --all
> As detailed here - https://proj.org/apps/projsync.html#index-0
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> Behalf Of pham lan
> Sent: Monday, March 27, 2023 4:02 PM
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] ERROR: transform: Point outside of projection
> domain (2050)
> Hi Regina,
> Here are more information:
> PROJ="Rel. 7.2.1, January 1st, 2021" GDAL="GDAL 3.2.3, released 2021/04/27"
> LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0"
> TOPOLOGY RASTER
> (1 row)
> On Mon, Mar 27, 2023 at 9:43 PM Regina Obe <lr at pcorp.us> wrote:
> What’s the structure of the table in question?
> \d+ name_of_table
> Should give needed details.
> Also output of
> Behalf Of pham lan
> Sent: Monday, March 27, 2023 3:27 PM
> Subject: [postgis-users] ERROR: transform: Point outside of projection
> domain (2050)
> Hi everyone,
> I need your help to figure this out. I have a DB in postgresql 10  with
> postgis 2.5. I know postgresql 10 is not supported anymore and we have plan
> to upgrade it soon but it is a different story.
> The thing is, I want to make a copy of this DB, so I tried a pg_basebackup
> to another postgres10+postgis 2.5 VM. After that, a vacuum went well but
> the analyzer throws an error on 1 specific table:
> i tried also pg_dump/pg_restore but get the same error. Does anyone know
> what is the problem?
> Thanks for your help!
> Regards,
> Lan
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230327/279a4328/attachment.htm>
