Clarification on ST_CoverageClean Parameters: snappingDistance and gapMaximumWidth
Douglas Fan
douglas.mhfan at gmail.com
Tue Sep 23 05:24:52 PDT 2025
Dear PostGIS Developers and Users,
First of all, thank you for the development of the new ST_CoverageClean
function in PostGIS 3.6.0. It’s a fantastic addition that has already
helped a lot in my work with polygonal coverages. I really appreciate the
effort that went into making this tool available.
While testing the function, I’ve encountered some behaviors that I’d like
to better understand, particularly regarding the snappingDistance and
gapMaximumWidth parameters.
>From the documentation, I understand that:
1. snappingDistance controls vertex snapping, with -1 applying an automatic
distance, and 0.0 disabling snapping.
2. gapMaximumWidth closes gaps smaller than the specified tolerance.
However, during testing with various combinations (e.g., snappingDistance
set to -1, 0.0, 1, 2 and gapMaximumWidth set to 0, 1, 2), I noticed:
1. Even when snappingDistance is explicitly set to 0.0, small sliver
vertices still appear to be snapped or altered when gapMaximumWidth is
greater than 0.
2. Slivers that are thinner than the gapMaximumWidth are removed, even when
they are not actual gaps or overlaps.
This behavior seems counterintuitive, as I expected no snapping to occur
with snappingDistance = 0.0. Could this be due to internal gap cleaning
logic that also affects vertex positions? Or is there an implicit snapping
step tied to gapMaximumWidth?
I’d be grateful for any insights into:
1. How do these two parameters interact?
2. Best practices or recommended workflows for cleaning polygonal coverages
with minimal geometry distortion.
3. Any known edge cases or limitations when using ST_CoverageClean.
4. Whether gapMaximumWidth also triggers geometry simplification or sliver
removal beyond gap closing.
Thanks in advance for your help and for the continued development of
PostGIS.
Best regards,
Man Ho Fan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250923/5bd9374f/attachment.htm>
