[Proj] Hi
Pieter Bosch
pieter.bosch at za.saabgroup.com
Tue Mar 17 05:03:45 PDT 2009
I've seen your text, and its been very help full.
I was asking this question because I've got a military map in my possession that states that it is in a Gauss Conformal projection and that the central meridian is at 23*East and also using wgs84 spheroid.
That central meridian of 23*East is not an interval of a Central meridian of a 6* or 3* zone width system
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Mikael Rittri
Sent: 17 March 2009 12:59 PM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Hi
Pieter wrote:
> I've got some information from the web that indicates that Gauss-Kruger divides zones of width 3*.
> I also found text saying its is the same as UTM with zones of 6* and that only the scale factor changes to 1.0 . Does any one know the real answer?
Both conventions exist, and a few more national ones.
See http://www.cartotalk.com/lofiversion/index.php?t3633.html for a discussion, and some more links.
In summary, if someone says "Gauss-Krüger zone number n", then you have not the slightest idea what it means...
Best regards,
Mikael Rittri
Carmenta AB
SWEDEN
www.carmenta.com
_______________________________
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Pieter Bosch
Sent: den 17 mars 2009 11:05
To: proj at lists.maptools.org
Subject: [Proj] Hi
Need some info.
I've got some information from the web that indicates that Gauss-Kruger divides zones of width 3*. I also found text saying its is the same as UTM with zones of 6* and that only the scale factor changes to 1.0 . Does any one know the real answer?
If I do a UTM with a scalefactor of 1.0 will that be a gauss kruger projection?
Anyone?
thanks
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
