[Proj] PROJ 5.0.0RC4
Mateusz Loskot
mateusz at loskot.net
Wed Feb 21 13:51:02 PST 2018
On 21 February 2018 at 17:27, Kristian Evers <kreve at sdfe.dk> wrote:
> All,
> I have just prepared PROJ 5.0.0RC4. Downloads are here:
> http://download.osgeo.org/proj/proj-5.0.0RC4.tar.gz
> (http://download.osgeo.org/proj/proj-5.0.0RC4.tar.gz.md5)
> http://download.osgeo.org/proj/proj-5.0.0RC4.zip
> (http://download.osgeo.org/proj/proj-5.0.0RC4.zip.md5)
> Changes from RC3 are minor. The PostGIS guys found a bug related to
> error-reporting otherwise no functional changes.
> RC3 has also seen more testing on Windows via the prerelease package added
> to OSGeo4W.
I've checked build & install of the RC4 on using VS2017 15.5.7
mkdir _build.vs2017x64 (or _build.vs2017x32 for 32-bit target)
cd _build.vs2017x64
cmake -G "Visual Studio 15 2017 Win64"
-DCMAKE_INSTALL_PREFIX:PATH=%CD%\_install.x64 ..
or
cmake -G "Visual Studio 15 2017"
-DCMAKE_INSTALL_PREFIX:PATH=%CD%\_install.x32 ..
cmake --build . --config Release --target install
ctest -C Release .
For both, 32 and 64 bit builds, this Builtins2 test is failing:
test 3
Start 3: Builtins2
3: Test command:
D:\tmp\proj-5.0.0rc4\_build.vs2017x32\bin\Release\gie.exe
"D:/tmp/proj-5.0.0rc4/test/gie/more_builtins.gie"
3: Test timeout computed to be: 1500
3: -------------------------------------------------------------------------------
3: Reading file 'D:/tmp/proj-5.0.0rc4/test/gie/more_builtins.gie'
3: pj_cart_selftest fails with 64
3: total: 44 tests succeeded, 4 tests skipped, 1 tests FAILED!
3/25 Test #3: Builtins2 ........................***Failed 0.21 sec
Is this expected?
BTW, I noticed the AppVeyor does not build with VS2017, is it intentional?
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
More information about the Proj
