[Proj] local inertial to GPS coordinates conversion
support at mnspoint.com support at mnspoint.com
Wed May 23 21:37:50 PDT 2018
Hello,
I suppose you try to ask that if you can get projected coordinates in
your local mapping datum (UTM 32) from global WGS84 datum Earth angular
coordinates or backwards? - YES! that is exactly what you can do with
proj!
Janne.
sravan kumar chaganti kirjoitti 2018-05-07 10:12:
> Hi,
> How  I would compute the Geo/GPS coordiantes from the inertial coordinates using the following proj string?
> +proj=utm +zone=32 +ellps=WGS84 +datum=WGS84 +units=m +no_defs
> is this projection string enough to compute the local inertial coordinates?
> Thanks
> sk
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
MNS Support
NNS Master Navigator Software
Copyright (c) Sapper Oy
www.mnspoint.com [1]
Links:
[1] http://www.mnspoint.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180524/d2b55630/attachment.html>
