[PROJ] PROJ 6RC2
Even Rouault
even.rouault at spatialys.com
Sat Feb 23 05:50:50 PST 2019
> I haven't rebuilt any reverse dependencies with PROJ 6.0.0 yet, as we
> can't transition to it in the near future anyway. But once that is done
> we should have an overview which package need to be patched to use
> proj_api.h or proj.h. Several of these packages aren't actively
> developed any more, so those patches will need to be contributed by
> someone experienced with the new APIs.
For the parts I maintain (with a lot of double quotes around """"maintain""""
for some of them),
- GDAL master / 2.5.0dev, to be released around May this year will require
PROJ 6 (GDAL 2.4 should probably already work fine with PROJ 6, since it uses
proj.h, but I didn't test)
- libgeotiff master / 1.5.0dev, to be probably released around the same time
of GDAL 2.5, will require PROJ 6. Current versions should likely work fine
since using proj_api.h if ACCEPT_USE_OF_DEPRECATED_PROJ_API_H is defined.
- the next version of shapelib will likely see its PROJ dependency removed
(only affects the contrib area) since I don't care about it:
https://lists.osgeo.org/pipermail/shapelib/2019-February/000645.html
- the next version of OGDI will likely see its PROJ dependency removed for the
same reason (it still uses project.h)
https://groups.yahoo.com/neo/groups/ogdidev/conversations/messages/314
- regarding MapServer, no immediate plan for action as far as I'm concerned.
It uses proj_api.h so ACCEPT_USE_OF_DEPRECATED_PROJ_API_H can be used for now.
Perhaps upgrading to proj.h would be a good topic for the OSGeo code sprint
for those who can attend.
Even
http://www.spatialys.com
More information about the PROJ
