[PROJ] PROJ 6RC2
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sat Feb 23 09:59:50 PST 2019
On 2019-02-23 9:50 AM, Even Rouault wrote:
>> I haven't rebuilt any reverse dependencies with PROJ 6.0.0 yet, as we
>> can't transition to it in the near future anyway. But once that is done
>> we should have an overview which package need to be patched to use
>> proj_api.h or proj.h. Several of these packages aren't actively
>> developed any more, so those patches will need to be contributed by
>> someone experienced with the new APIs.
> For the parts I maintain (with a lot of double quotes around """"maintain""""
> for some of them),
> - GDAL master / 2.5.0dev, to be released around May this year will require
> PROJ 6 (GDAL 2.4 should probably already work fine with PROJ 6, since it uses
> proj.h, but I didn't test)
> - libgeotiff master / 1.5.0dev, to be probably released around the same time
> of GDAL 2.5, will require PROJ 6. Current versions should likely work fine
> since using proj_api.h if ACCEPT_USE_OF_DEPRECATED_PROJ_API_H is defined.
> - the next version of shapelib will likely see its PROJ dependency removed
> (only affects the contrib area) since I don't care about it:
> https://lists.osgeo.org/pipermail/shapelib/2019-February/000645.html
> - the next version of OGDI will likely see its PROJ dependency removed for the
> same reason (it still uses project.h)
> https://groups.yahoo.com/neo/groups/ogdidev/conversations/messages/314
> - regarding MapServer, no immediate plan for action as far as I'm concerned.
> It uses proj_api.h so ACCEPT_USE_OF_DEPRECATED_PROJ_API_H can be used for now.
> Perhaps upgrading to proj.h would be a good topic for the OSGeo code sprint
> for those who can attend.
Many thanks Even for this roadmap of timing for GDAL, libgeotiff and
PROJ 6. Regarding MapServer, I wonder this would be good for the 7.4.0
release goals.
-jeff
More information about the PROJ
