[PROJ] PROJ 6.0.0RC3
Even Rouault
even.rouault at spatialys.com
Wed Feb 27 00:10:28 PST 2019
> The "test ==" problem in configure is still present.
Ah, I had actually missed that comment since it worked just fine with a manual
build (that is outside of the packaging infrastructure you use)
I've just captured that in https://github.com/OSGeo/proj.4/pull/1295
Do not hesitate to submit a PR another time
even
http://www.spatialys.com
More information about the PROJ
