[PROJ] Canada Lambert Conformal Conic Projection
James Banting
jbanting at sparkgeo.com
Fri Apr 10 15:08:10 PDT 2020
Hi All,
I'm creating a STAC catalog for Canada's SPOT4/5 orthoimagery <https://open.canada.ca/data/en/dataset/d799c202-603d-4e5c-b1eb-d058803f80f9> and I’d like to build a proj json file and include it in the STAC items.
The proj json schema files seem to indicate that I need an `id` object with `authority` and `code` to be compliant. Since the projection (Canada Lambert Conformal Conic [CSRS]), doesn’t have an EPSG code, I used this:
"id": {
"authority": "CANLAMB-CSRS",
"code": 1
Is this acceptable in proj world? It’s been a while since I’ve had to touch projection files.
As a reference, this is the documentation for the CANLAMB projection <http://ftp.geogratis.gc.ca/pub/nrcan_rncan/image/spot/geobase_orthoimages/doc/GeoBase_spot_en_Orthoimage_Specifications.pdf> (pg 9 of the document, 15 of the pdf) and I’ve attached my take at the proj json file.
Thanks,
James Banting
Sparkgeo
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200410/c13e455a/attachment.html>
Type: application/json
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200410/c13e455a/attachment.json>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200410/c13e455a/attachment-0001.html>
More information about the PROJ
