[PROJ] Canada Lambert Conformal Conic Projection
Even Rouault even.rouault at spatialys.com
Fri Apr 10 16:07:08 PDT 2020
James,
Several points:
- this is actually EPSG:3979, "NAD83(CSRS) / Canada Atlas Lambert"
  The only difference is the switch between the latitude of 1st and 2nd
  std parallel, but this is numerically equivalent for LCC_2SP.
  The following remarks are then a bit auxiliary now :-)
- there's an extra space at the end of the top name
- authority = CANLAMB-CSRS would be odd to me. An authority must be something
  identifiable, like some form of organization, that can issue several
  records. CANLAMB-CSRS would be more an id for this CRS for some authority
  XXXX. But I do see in the PDF you mention that they use this...
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200411/d1f16753/attachment.html>
More information about the PROJ mailing list
