[PROJ] World UTM in a proper datum
Noel Zinn (cc)
ndzinn at comcast.net
Sat Apr 17 14:59:16 PDT 2021
We really need two codes, don’t we? One for the geographical datum (ITRF2014 in GRS80, which is EPSG:7789 in your case) and one for the projection UTM in GRS80 (which, I guess, doesn’t exist), perhaps an EPSG architecture problem. To be frank, your expectation that the EPSG do for ITRF2014 what it’s done for WGS84/UTM is unrealistic. Add ITRF2008 and so on, how many combinations would that be?
Sent: Saturday, April 17, 2021 3:56 PM
To: Noel Zinn (cc)
Cc: proj
Subject: Re: [PROJ] World UTM in a proper datum
Hi Noel,
If I am the only user of the data, I can do that (and whatever I want). But if I have to produce accurate data processed by somebody else, I fall into the hole of vagueness of WGS84. For instance, if I create a precise GeoTIFF and I want to tag it with an EPSG, using EPSG:326XX is... vague. Or a GCP, or anything else. There are several alternatives for the geographic crs.
I know I can apply UTM over ITRF2014 (GDAL does it easily). But there is no EPSG code for that.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Sat, 17 Apr 2021 at 22:24, Noel Zinn (cc) <ndzinn at comcast.net> wrote:
Unlike an empirically-derived datum transformation (e.g. WGS <> ITRF), which can have different levels of "accuracy" depending how it was derived, a map projection (lat/lon <> N/E) is defined mathematically and is precise, i.e. without error. Having said that, there are better and worse algorithms for UTM, but that's not the question you're asking. In a datum transformation sense UTM will always be as (and only as) "accurate" as the geographicals you convert to N/E. So, use EPSG:326XX and EPSG327XX, but plug in your precise geographicals.
Sent: Saturday, April 17, 2021 2:44 PM
To: proj
Subject: [PROJ] World UTM in a proper datum
Hi
Maybe there is a better place to talk about this, but I do not know which one. I hope somebody from EPSG is reading this, and may give me a clue.
We have talked many times about the lack of accuracy of WGS84 (EPSG:4326), the datum ensemble, etc.
The problem is that I miss an accurate equivalent of the projected family "WGS84 / UTM zone XXY"(EPSG:326XX and EPSG327XX) for XX between 1 and 60 and Y is N or S. It would be nice something similar (a worldwide projected CRSs on UTM), but over a proper accurate and well defined geographic CRS (ITRF2014, WGS84(G1762), etc).
Do you know if there is any plan? Or do they exist and I was not able to find them?
Thanks.
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210417/a1861b90/attachment-0001.html>
More information about the PROJ
