[PROJ] missing docker image osgeo/proj:8.2.1
Javier Jimenez Shaw j1 at jimenezshaw.com
Sat Jan 8 14:22:18 PST 2022
Hi
Trying to pull the docker image for version 8.2.1, I got an error
$ docker pull osgeo/proj:8.2.1
Error response from daemon: manifest for osgeo/proj:8.2.1 not found:
manifest unknown: manifest unknown
checking in hub.docker.com, I found it is not there:
https://hub.docker.com/r/osgeo/proj/tags?page=1&name=8.
The last tagged versioned is 8.2.0
Is there any reason for that?
Are docker images part of the release process?
note: tags 8.1.1 and 8.2.0 were pushed by user 'hobu', while the previous
tags by 'osgeo'
Thanks.
Javier
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220108/181070ea/attachment.html>
More information about the PROJ mailing list
