[PROJ] OGRCreateCoordinateTransformation()
    Even Rouault
    even.rouault at spatialys.com
    Mon Mar 28 14:07:24 PDT 2022
Le 28/03/2022 à 23:02, Steve Riddell a écrit :
> Hi Even,
> It’s working now, for my two test cases, --- as long as there’s a
> TOWGS84[0, 0, 0, 0, 0, 0, 0] field in the WKT w/ the geoid grid. I’m
> guessing that ties the grid to the datum/geogcs of the containing
> compound CRS?
yes. That works also for me if there's no TOWGS84[], but then PROJ will
issue a more complicated pipeline doing a non-null horizontal datum
shift from NAD83(CSRS) to WGS 84, since (without PR3216/3217), it
assumes that the vertical grid is referenced to WGS 84.
> Thanks!
> Steve
> *From:* Even Rouault <even.rouault at spatialys.com>
> *Sent:* Monday, March 28, 2022 3:15 PM
> *To:* Steve Riddell <sriddell at geocue.com>; proj <proj at lists.osgeo.org>
> *Cc:* Suresh Jakka <sjakka at geocue.com>
> *Subject:* Re: OGRCreateCoordinateTransformation()
> Steve,
>     Sorry for the delay, but I’ve now tested with PR3216, alone, and
>     then with PR3127.  I’m getting the same behavior as I reported
>     below.   Perhaps my best chance at getting this to work is to
>     either directly make proj calls, or construct the pipeline myself
>     and pass through gdal?
> That was indeed an entirely different issue. Fix queued in
> https://github.com/OSGeo/PROJ/pull/3147
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220328/f74ba843/attachment.html>
More information about the PROJ
