[PROJ] Pipeline: Cartesian transform to change from ellipsoid to sphere
Even Rouault
even.rouault at spatialys.com
Mon Aug 12 09:57:21 PDT 2024
Le 12/08/2024 à 18:44, Laura, Jason R via PROJ a écrit :
> List,
> I have a set of body-centered body-fixed coordinates that were
> computed with an ellipsoid of +a=3396190 +b=3376200. I am attempting
> to reproject these into a spherical datum (+R=3396190) using the
> pipeline syntax. For example,
> +proj=pipeline +units=m
> +step +proj=cart +a=3396190 +b=3376200
> +step +proj=cart +R=3396190
> Which is failing with a unit warning. I suspect I am missing something
> basic.
You need to add +inv in the last step to go from ECEF to lon-lat
coordinate space
> I have looked at the geodesic -> Helmert -> geodesic transformation
> tutorial, but I am clearly misunderstanding something
> (https://proj.org/en/9.3/tutorials/EUREF2019/exercises/pipelines.html#geodetic-helmert-geodetic)
> Looking at these docs, I tried:
> +proj=pipeline
> +step +proj=helmert +z=19990 +convention=position_vector
> +step +inv +proj=cart +R=3396190
> But I get an invalid latitude error (which I believe means I am
> misspecifying the input system).
Works for me. The input coordinate order is longitude, latitude, Z.
> Any suggestions appreciated,
> Jay
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240812/e4b7b3cd/attachment.htm>
More information about the PROJ
