[PROJ] Dealing with epoch and transformations
Javier Jimenez Shaw
j1 at jimenezshaw.com
Fri Aug 23 02:28:20 PDT 2024
Hi
I am a bit confused with the epoch of coordinates. For instance, if I
connect to this NTRIP service
https://support.swiftnav.com/support/solutions/articles/44002386941-configuring-your-receiver
it says explicitly that "Skylark Nx RTK uses ITRF2020 reference frame."
Does it mean that the coordinates that I measure today do have an epoch of
2024.x (today's epoch), or the epoch of those measurements is 2015.0 (the
epoch of ITRF2020
https://epsg.org/datum_1322/International-Terrestrial-Reference-Frame-2020.html
If I want to transform from that reference system (ITRF2020) to, let's say,
ETRS89 or NAD83(2011), should I add an epoch? which one? where? what
happens if I do not set any?
I have the impression that I could convert from one epoch to another for
the same CRS, something like this
PROJ_DATA=data ./bin/projinfo -s EPSG:9989 -t EPSG:9989 --s_epoch 2015.0
--t_epoch 2020.0 -o proj
Candidate operations found: 1
Operation No. 1:
unknown id, Null geographic offset from ITRF2020 to ITRF2020, 0 m, World.
PROJ string:
+proj=noop
... but it does not. Should it do a non noop transformation?
Note: s_epoch and t_epoch were added in PROJ 9.4
Thanks.
PS. ITRF2020 to CH1903+ is a complete ballpark :(
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240823/1fe018b7/attachment.htm>
More information about the PROJ
