[PROJ] geodtest/planimeter test failure
Charles Karney
charles.karney at gmail.com
Sat Sep 14 17:28:40 PDT 2024
I recommend you start with the sin(-90) != -1 failure. In particular
can you check the inputs
x, (double)qd
and outputs
r, q
of the call to remquo in sincosdx in geodesic.c line 179. Buggy
implementations of remquo have been a problem in the past.
Thanks...
--Charles
On 9/14/24 2:26 PM, Greg Troxel via PROJ wrote:
> I have several failing tests. I'm going to post about them in small
> groups, because I suspect they might have a common cause. I realize the
> problem could be in my toolchain. I'll rerun paranoia and NetBSD's
> regression tests.
> My first question is: Do regression tests all pass for everyone else, on
> all platforms they try to run them on? If anyone has a clean pass on
> anything that isn't windows/mac/linux, please email me privately and
> I'll summarize. If you have any failures, please post here.
> My environment
> NetBSD 10 (up to date with the branch)
> gcc version 10.5.0 (nb2 20230710)
> building with cmake in a build directory
> 9th gen i7, dell workstation (not an odd computer)
> geodtest prints:
> checkEquals fails: 1.001875e+07 != 3.002268e+07 +/- 1
> checkEquals fails: 1.001875e+07 != 2.002072e+07 +/- 1
> Planimeter0 fail: 2
> checkEquals fails: 7.612398e-07 != 1000000 +/- 0.01
> Planimeter29 fail: 1
> Looking at Planimeter0 and quoting sparsely, the failing tests are
> these, on the same inputs.
> double pd[3][2] = {{90, 0}, {0, 0}, {0, 90}};
> planimeter(&g, pd, 3, &perimeter, &area);
> result += checkEquals(perimeter, 30022685, 1);
> result += checkEquals(area, 63758202715511.0, 1);
> polylength(&g, pd, 3, &perimeter);
> result += checkEquals(perimeter, 20020719, 1);
> Do others build with -ffloat-store to avoid extended precision? (I
> didn't find any such instructions in the readme.)
> Planimeter29:
> geod_init(&g, wgs84_a, wgs84_f);
> geod_polygon_init(&p, 0);
> geod_polygon_addpoint(&g, &p, 0, 0);
> geod_polygon_addedge(&g, &p, 90, 1000);
> geod_polygon_addedge(&g, &p, 0, 1000);
> geod_polygon_addedge(&g, &p, -90, 1000);
> geod_polygon_compute(&g, &p, 0, 1, &area, nullptr);
> /* The area should be 1e6. Prior to the fix it was 1e6 - A/2, where
> * A = ellipsoid area. */
> result += checkEquals(area, 1000000.0, 0.01);
> geodsigntest prints:
> Line 149: sin(-90) != -1 (1)
> 1 failure
> due to
> #define checksincosd(x, s, c) do { \
> T sx, cx; \
> geod_sincosd(x, &sx, &cx); \
> if (equiv(s, sx)) { \
> printf("Line %d: sin(%g) != %g (%g)\n", \
> __LINE__, x, s, sx); \
> ++n; \
> if (equiv(c, cx)) { \
> printf("Line %d: cos(%g) != %g (%g)\n", \
> __LINE__, x, c, cx); \
> ++n; \
> } while (0)
> checksincosd(- 90.0, -1.0, +0.0);
> I'll keep looking, but any clues appreciated.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Charles Karney <karney at alum.mit.edu>
702 Prospect Ave
Princeton, NJ 08540-4037
More information about the PROJ
