[PROJ] geodtest/planimeter test failure
Greg Troxel
gdt at lexort.com
Sun Sep 15 17:29:54 PDT 2024
Charles Karney <charles.karney at gmail.com> writes:
> I recommend you start with the sin(-90) != -1 failure. In particular
> can you check the inputs
> x, (double)qd
> and outputs
> r, q
> of the call to remquo in sincosdx in geodesic.c line 179. Buggy
> implementations of remquo have been a problem in the past.
You are spot on; my libm remquo is buggy. I'm working on fixing that,
and then will see what remains.
(Thus far, I have received no reports of proj tests passing on a
platform other than linux/mac/windows.)
More information about the PROJ
