[PROJ] 9.6.0 sharp embed compiler test on gcc7
Greg Troxel gdt at lexort.com
Sat May 3 06:34:27 PDT 2025
Even Rouault <even.rouault at spatialys.com> writes:
> A fix for that has been merged in the 9.6 branch (post 9.6.0, for
> 9.6.1) per https://github.com/OSGeo/PROJ/pull/4463
Thanks, am cherry-picking that into pkgsrc.  With gcc 10 the build diff
is that the following lines vanish, changing a failing embed test into
"not trying because gcc10 < gcc15".
  -- Performing Test _TEST_SHARP_EMBED
  -- Performing Test _TEST_SHARP_EMBED - Failed
With NetBSD 9 and gcc 7, it also successfully built.
Tests pass except for spilhaus, which I realize is new and I'll look
into that - surely not relatd to C23/embed.
>> I also don't understand how C23 is handled if sharp embedding is turned
>> on.  It would seem one has to end up passing --std for it, because a
>> compiler that can compile C23 does not necessarily default to it.
> Cf
> https://github.com/OSGeo/PROJ/blob/41139273222d1a5937ff6abcf16350f6ed7db773/src/lib_proj.cmake#L429
> that selectively enables C23 for targets that need it when
> IS_SHARP_EMBED_AVAILABLE_RES is set.
Ah, did not guess that from the original cmake code, but makes sense.
>> Does this work for others on compilers that don't support C23?
> If they are not too old yes.
It worked with 7 which is my current take on "oldest gcc that is not
unreasonably ancient" but idk what's up with older RHEL and older ubuntu
that people run, these days.
More information about the PROJ mailing list
