[PROJ] QGIS seems to transform with height 0 instead of the actual height
    Lesparre, Jochem
    Jochem.Lesparre at kadaster.nl
    Thu May 15 06:23:50 PDT 2025
I have coordinates of a triangulation pilar in EPSG:10645 (compound projected CRS: DPnet Saba + Saba height) in an input file:
echo 4740.3800 1890.1200 870.3900 > input.txt
The transformation to EPSG:10638 (3D geographic CRS: BES2020 Saba) with PROJ 9.6.0 gives correct results:
cs2cs epsg:10645 epsg:10638 --only-best -f %.9f input.txt
17.635528781    -63.237251291 827.6282[...]
I saved the output coordinates to file:
     echo 17.635528781 -63.237251291 827.6282 > output.txt
The used transformation is:
projinfo -s epsg:10645 -t epsg:10638 -o proj
Candidate operations found: 4
Operation No. 1:
unknown id, Inverse of Saba Transverse Mercator 2020 + Inverse of Saba to Saba height (1) + Saba to BES2020 Saba (1),
However, the location of input.txt and output.txt is visually 0.1 m different in QGIS (version 3.42.2):
- open input.txt in QGIS (field_1, field_2, field_3 as EPSG:10645)
- open output.txt in QGIS (field_2, field_1, field_3 as EPSG:10638), where I selected this transformation (the inverse of the transformation used by cs2cs):
Inverse of Saba to BES2020 Saba (1) + Saba to Saba height (1) + Saba Transverse Mercator 2020
The wrong visualisation of the location of output.txt can be exported in QGIS as CSV geometry AS_XYZ:
4740.3647[...],1890.2050[...],827.6282[...]
This is exactly the xy that I get when I transform output.txt back to EPSG:10645 with zero height:
echo 17.635528781 -63.237251291 0 | cs2cs epsg:10638 epsg:10645 --only-best -f %.4f
4740.3647       1890.2052 42.4286
Is this the intended behaviour for QGIS? I don't like it...
Jochem
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250515/f8907ed1/attachment.htm>
More information about the PROJ
