[PROJ] QGIS seems to transform with height 0 instead of the actual height
    Javier Jimenez Shaw
    j1 at jimenezshaw.com
    Thu May 15 08:13:16 PDT 2025
Do you suggest that QGIS is doing the operation at height 0, and not 870?
I have the impression that you are asking at the wrong mailing list ;) (but
I am not in QGIS one, maybe you asked there as well)
On Thu, 15 May 2025 at 15:23, Lesparre, Jochem via PROJ <
proj at lists.osgeo.org> wrote:
> I have coordinates of a triangulation pilar in EPSG:10645 (compound
> projected CRS: DPnet Saba + Saba height) in an input file:
> echo 4740.3800 1890.1200 870.3900 > input.txt
> The transformation to EPSG:10638 (3D geographic CRS: BES2020 Saba) with
> PROJ 9.6.0 gives correct results:
> cs2cs epsg:10645 epsg:10638 --only-best -f %.9f input.txt
> 17.635528781    -63.237251291 827.6282[...]
> I saved the output coordinates to file:
>      echo 17.635528781 -63.237251291 827.6282 > output.txt
> The used transformation is:
> projinfo -s epsg:10645 -t epsg:10638 -o proj
> Candidate operations found: 4
> Operation No. 1:
> unknown id, Inverse of Saba Transverse Mercator 2020 + Inverse of Saba to
> Saba height (1) + Saba to BES2020 Saba (1),
> However, the location of input.txt and output.txt is visually 0.1 m
> different in QGIS (version 3.42.2):
> - open input.txt in QGIS (field_1, field_2, field_3 as EPSG:10645)
> - open output.txt in QGIS (field_2, field_1, field_3 as EPSG:10638), where
> I selected this transformation (the inverse of the transformation used by
> cs2cs):
> Inverse of Saba to BES2020 Saba (1) + Saba to Saba height (1) + Saba
> The wrong visualisation of the location of output.txt can be exported in
> QGIS as CSV geometry AS_XYZ:
> 4740.3647[...],1890.2050[...],827.6282[...]
> This is exactly the xy that I get when I transform output.txt back to
> EPSG:10645 with zero height:
> echo 17.635528781 -63.237251291 0 | cs2cs epsg:10638 epsg:10645
> --only-best -f %.4f
> 4740.3647       1890.2052 42.4286
> Is this the intended behaviour for QGIS? I don’t like it…
> Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de
> geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden
> van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you are not the intended recipient, you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents of
> this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products and
> services
> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250515/c67f79c9/attachment-0001.htm>
More information about the PROJ
