[PROJ] QGIS seems to transform with height 0 instead of the actual height
    Lesparre, Jochem
    Jochem.Lesparre at kadaster.nl
    Thu May 15 08:33:10 PDT 2025
Javier wrote:
> Do you suggest that QGIS is doing the operation at height 0, and not 870?
Yes, actually 827 m ellipsoidal height, which is 870 m physical height.
> I have the impression that you are asking at the wrong mailing list ;) (but I am not in QGIS one, maybe you asked there as well)
As it is a very coordinate transformation related issue, I thought it would be good to first ask it here, also to check if my analysis is correct.
Jochem
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250515/de2fabac/attachment.htm>
More information about the PROJ
