[PROJ] Help with custom CRS proj string
Javier Jimenez Shaw
j1 at jimenezshaw.com
Fri May 30 06:20:21 PDT 2025
This works for me. See that cct needs 3 coordinates. x,y,z
$ echo 59770.038 101069.654 0 | cct +proj=helmert +x=334491.216
+y=6950332.853 +theta=-49800
368362.0519 7062761.9368 0.0000 inf
On Wed, 21 May 2025 at 00:36, Daniel Farfán via PROJ <proj at lists.osgeo.org>
wrote:
> I've been trying to solve this problem but was unable to, so I kindly
> ask for help.
> I have 3 coordinate points in a local grid:
> A': 59770.038, 101069.654
> B': 59214.93435, 98996.58573
> C': 58444.7795, 99231.37298
> Corresponding coordinate points in EPSG:32719 CRS:
> A: 368362.117, 7062761.917
> B: 368318.78, 7060616.253
> C: 367514.826, 7060660.088
> So, I've determined that to convert from the local points to the
> EPSG:32719 CRS, I have to displace the x axis by 334491.216, the y
> axis by 6950332.853, and rotate counterclockwise by 13.8333 degrees.
> I have managed to get the following to work:
> cct +proj=helmert +x=334491.216 +y=6950332.853 +theta=-49800
> When I input the coordinates in the local grid, i get the
> corresponding coordinates in EPSG:32719
> What I'm struggling with is to use the conversion with cs2cs: i think
> I need to define the transformation as a custom CRS, to be able to do
> something like:
> cs2cs "+proj=helmert +x=334491.216 +y=6950332.853 +theta=-49800" +to
> EPSG:32719
> but that's not working.
> My final goal is to use the custom CRS proj string (or WKT equivalent)
> in GDAL and QGIS to be able to transform on the fly the local grid
> data to EPSG:32719.
> Any help would be appreciated. Thanks in advance.
> Daniel Farfán
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250530/e18b12aa/attachment.htm>
More information about the PROJ
