[PROJ] Horner - polynomial solving in 3D
Norman Barker
norman.barker at gmail.com
Wed Apr 29 16:54:06 PDT 2026
Looking at https://proj.org/en/stable/operations/transformations/horner.html
it mentions the domain being 2D and 3D. I also looked at the code and read
more about Horner and it seems that I can apply Horner on two dimensions
and then the third.
My problem is that I have a moving coordinate frame (in ECEF) that is a
function of time, it is representing a sensor in space. Each frame unit
vector UX, UY, and UZ is specified as the coefficients of a polynomial in
X, Y, and Z (ECEF) that is dependent on time (t).
Using a proj string I am hoping that I can pass in a coordinate `t` to
generate the XYZ coordinates which I can then pass down the pipeline.
Is this possible, if so how do I use Horner with three dimensional data?
Many thanks,
Norman
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260429/968b4fe5/attachment-0001.htm>
More information about the PROJ
