[PROJ] Synthetic Coordinate System
Martin Desruisseaux
martin.desruisseaux at geomatys.com
Tue Mar 24 01:44:02 PDT 2026
Hello Ben
Le 23/03/2026 à 21:21, Ben Griffin via PROJ a écrit :
> As I understand it - and I am happy to be corrected, it appears that you are confirming that there is not (yet) an
> agreed standard as to what a DGGS should be in ISO terms.
There is an ISO standard for DGGS, which is ISO 19170-1 at
https://www.iso.org/standard/32588.html. The same standard is available
for free on the OGC web site at
https://docs.ogc.org/as/20-040r3/20-040r3.html. This is a joint OGC/ISO
standard, like ISO 19111 which is identical to "OGC Topic 2" except for
the cover and formatting.
However, PROJ's C++ API is derived from ISO 19111, and that standard has
not been designed for DGGS. There is no plan to adapt ISO 19111 to DGGS,
at least in the current ISO 19111 revision work. If PROJ wanted to
introduce an API for the referencing part of DGGS, ISO 19112 may be a
better model. I just saw that ISO 19170 references ISO 19112 in its list
of normative references, so it seems that there is some agreement about
its pertinence. We have used ISO 19112 years ago as an API for Military
Grid Reference System (MGRS) and it worked well. My impression is that
the use of ISO 19112 for modelling an API for DGGS during the OGC
Testbed this year gave good results as well.
> My work - Hex9 - straddles both standards cleanly:
> - The projection (continuous CRS) — ISO 19111
> - The addressing system (H9 cell hierarchy) — ISO 19112
Yes, I think that this is the way that it has been implemented in at
least part of the OGC Testbed. The Testbed reports should be published
later this year normally, maybe in autumn.
Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260324/9406b0ae/attachment.htm>
More information about the PROJ
