[Pywps-dev] how to using GeoServer REST API to save output data to GeoServer
Jachym Cepicky
jachym.cepicky at gmail.com
Mon May 20 23:27:26 PDT 2013
Jorge,
do I understand it correctly, that all proposed libraries are to be used
at server side - so inside of PyWPS?
In which way are you proposing using REST approach inside of PyWPS? My
ideas would be:
1 - using it for administration (list of running processes, statistics,
stoping/pausing/starting process (NOTE: future version of WPS will
include this features as well) ...
2 - Along with "old" way of defining and deploying processes, we could
use REST services to do so
3 - make completely new proprietary design of processing service
(something like web processing server, demonstrated along with
OpenLayers some years ago)
4 - anything else?
About the templates: I would like to KISS pywps - helping libraries are
as good, as they are helping. My original idea was, to use lxml for
output xml generation, so no templates needed. What's your opinion?
Jachym
Dne 21.5.2013 08:12, Jorge de Jesus napsal(a):
> Hola
> I think that GeoServer REST API is nice and well documented if, we use
> it as reference point we will have a great start.
> 1 year go my college Olly suggested to do REST services using Flask [1]
> I've done a REST access in ISRIC using Flask, the framework performed
> pretty well I only had some problems with pyscopg2 and cursors but this
> problem is independent from Flask. Also Django-REST looks nice [2], and
> future developments on my side will use Django-REST.
> Flask uses Jinja [3] as template engine, it seems that template engines
> and webframes are breeding like rabbits :)
> Any considerations for the new template engine ??? We need to shop
> around for new tools and frameworks, Python has come a long long way
> since PyWPS started.
> Jorge
> [1] http://flask.pocoo.org/
> [2] http://django-rest-framework.org/
> [2] http://jinja.pocoo.org/
> On 05/20/2013 04:17 AM, welkin zzp wrote:
>> Hi Jachym
>> I want to implement the function that write output data to
>> GeoServer , but I have not used Geoserver and not very familiar with
>> the Geoserver REST API , Can you give me some advice on how to implement
>> this feature in pywps ?
>> Thanks
>> pywps-dev mailing list
>> pywps-dev at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
Jachym Cepicky
Help Service - Remote Sensing s.r.o.
HS-RS: jachym at hsrs.cz http://bnhelp.cz
http://les-ejk.cz
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20130521/15d91261/attachment.pgp>
More information about the pywps-dev
