[Pywps-dev] mvc in pywps - django?
Tom Kralidis tomkralidis at hotmail.com
Sat May 25 13:27:48 PDT 2013
Hi Jachym: thanks for the info.
Having worked on pycsw in GeoNode, I can say it would be extremely valuable to have Django type integration, and the project has had much success with this seamless type of integration.
You'll want to check out EOxServer (http://eoxserver.org/) for a similar approach, where Django is used to manage resources which are then made available via WCS, etc.
For PyWPS, I would think Django would be a type of "backend" for managing processes, in addition to traditional methods.
Date: Sat, 25 May 2013 21:19:24 +0200
To: pywps-dev at lists.osgeo.org
Subject: [Pywps-dev] mvc in pywps - django?
during coding of the new pywps parsing mechanism, I was thinking about
totally different concept of PyWPS, it could be complain more to the mvc
(model view controller) paradigm.
Right now, when the user wants to configure process, he have to write
all the configuration from scratch. But what if we would have mechanism,
where you can store all data input and data output types, and you would
just "add" this particular data ins/outs to particular process.
Process configuration would then not be about writing all "complex
raster input" definition again and again, it would be about "add
standard complex raster input" from your library. Don’t Repeat Yourself.
Similar to GeoServer - data store, once created, can be used multiple
times for several layers.
I hope, you can follow my thoughts up to this point. And I think, that
django would be the tool on this place, which would enable such
approach. It can use several database engines, it contains templating
system ... hmm.
PyWPS would probably not be that slick little envelop. But would we gain
something more, when relayed on django?
Any thoughts?
Jachym
Jachym Cepicky
Help Service - Remote Sensing s.r.o.
jachym.cepicky at gmail.com
HS-RS: jachym at hsrs.cz http://bnhelp.cz
http://les-ejk.cz
pywps-dev mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
More information about the pywps-dev mailing list
