[Pywps-dev] Containerization PyWPS processes
Jachym Cepicky jachym.cepicky at gmail.com
Wed Sep 20 09:38:49 PDT 2017
I'm in touch with Adam.
 It has big impact on the disc space, I agree - but afaik, it opens new
possibilities (imagine, being able to deploy running job to e.g. open shift
instaces ..) and other system resources impact should not  be that big?
What can I say, all the points raised by Jorge are valid - so let's give it
a try?
J
st 20. 9. 2017 v 18:07 odesílatel jorge.dejesus <jorge.dejesus at geocat.net>
napsal:
> Hi to all
> Interresting research topic, but you have a problem with that approach:
> starting the process will have a massive overhead (compared with a thread)
> and will consume alot of disk space and resources  !!!
> You would have to create the docker image and process  when you install
> pywps , and then start the docker when the user calls the process.  I am a
> bit against using such a big system in PyWPS unless someone tries to
> implement it and run it and show or not that is feasable, *we dont know
> it until we try it*
> Those were my 2cent :)
> J.
> On 20-09-17 15:41, Adam Laža wrote:
> Hi devs,
> I am student of geoinformatics at CTU in Prague. Currently I'm looking for
> my ma final thesis topic. Yesterday I met with Jachym and we discussed
> about containerization PyWPS processes (probably with Docker). It could be
> handy for killing/pausing a process which is as far as I know quite crucial
> in WPS 2.0.
> I'd like to know if somebody already researched this posibility or whether
> you have any suggestion or advice.
> Thanks in advance.
> Adam
> pywps-dev mailing listpywps-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20170920/23b1913c/attachment.html>
More information about the pywps-dev mailing list
