[QGIS Commit] r14308 - in trunk/qgis/src: core/symbology-ng
gui/symbology-ng ui
svn_qgis at osgeo.org
Tue Sep 28 20:26:34 EDT 2010
Author: cfarmer
Date: 2010-09-29 00:26:34 +0000 (Wed, 29 Sep 2010)
New Revision: 14308
trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp
trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.h
trunk/qgis/src/gui/symbology-ng/qgsgraduatedsymbolrendererv2widget.cpp
trunk/qgis/src/ui/qgsgraduatedsymbolrendererv2widget.ui
Adds three new classification modes to graduated symbol renderer (version 2), including Natural Breaks (Jenks), Standard Deviations, and Pretty Breaks (based on pretty from the R statistical environment)
Modified: trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp 2010-09-28 20:41:38 UTC (rev 14307)
+++ trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp 2010-09-29 00:26:34 UTC (rev 14308)
@@ -1,4 +1,16 @@
+qgsgraduatedsymbolrendererv2.cpp - Graduated Symbol Renderer Version 2
+* This program is free software; you can redistribute it and/or modify *
+* it under the terms of the GNU General Public License as published by *
+* the Free Software Foundation; either version 2 of the License, or *
+* (at your option) any later version. *
#include "qgsgraduatedsymbolrendererv2.h"
#include "qgssymbolv2.h"
@@ -12,6 +24,8 @@
#include <QDomDocument>
#include <QDomElement>
#include <QSettings> // for legend
+#include <limits> // for jenks classification
+#include "math.h" // for pretty classification
QgsRendererRangeV2::QgsRendererRangeV2( double lowerValue, double upperValue, QgsSymbolV2* symbol, QString label )
: mLowerValue( lowerValue ), mUpperValue( upperValue ), mSymbol( symbol ), mLabel( label )
@@ -273,6 +287,12 @@
static QList<double> _calcEqualIntervalBreaks( double minimum, double maximum, int classes )
+ // Equal interval algorithm
+ // Returns breaks based on dividing the range ('minimum' to 'maximum')
+ // into 'classes' parts.
double step = ( maximum - minimum ) / classes;
QList<double> breaks;
@@ -287,11 +307,7 @@
static QList<double> _calcQuantileBreaks( QList<double> values, int classes )
- // sort the values first
- qSort( values );
- QList<double> breaks;
// q-th quantile of a data set:
// value where q fraction of data is below and (1-q) fraction is above this value
// Xq = (1 - r) * X_NI1 + r * X_NI2
@@ -300,6 +316,11 @@
// r = q * (n+1) - (int) (q * (n+1))
// (indices of X: 1...n)
+ // sort the values first
+ qSort( values );
+ QList<double> breaks;
int n = values.count();
double q, a, aa, r, Xq;
for ( int i = 0; i < ( classes - 1 ); i++ )
@@ -319,6 +340,328 @@
return breaks;
+static QList<double> _calcPrettyBreaks( double minimum, double maximum, int classes )
+ // C++ implementation of R's pretty algorithm
+ // Based on code for determining optimal tick placement for statistical graphics
+ // from the R statistical programming language.
+ // Code ported from R implementation from 'labeling' R package
+ // Computes a sequence of about 'classes' equally spaced 'round' values
+ // which cover the range of of values from 'minimum' to 'maximum'.
+ // The values are chosen so that they are 1, 2 or 5 times a power of 10.
+ if ( classes < 1 )
+ breaks.append( maximum );
+ return breaks;
+ int minimumCount = (int) classes / 3;
+ double shrink = 0.75;
+ double highBias = 1.5;
+ double adjustBias = 0.5 + 1.5 * highBias;
+ int divisions = classes;
+ double h = highBias;
+ double cell;
+ int U;
+ bool small = false;
+ double dx = maximum - minimum;
+ if ( dx == 0 and maximum == 0 )
+ cell = 1.0;
+ small = true;
+ U = 1;
+ else
+ cell = qMax( qAbs( minimum ), qAbs( maximum ) );
+ if ( adjustBias >= 1.5 * h + 0.5 )
+ U = 1 + (1.0/(1 + h));
+ else
+ U = 1 + (1.5 / (1 + adjustBias));
+ small = dx < ( cell * U * qMax( 1, divisions ) * 1e-07 * 3.0 );
+ if ( small )
+ if ( cell > 10 )
+ cell = 9 + cell / 10;
+ cell = cell * shrink;
+ if ( minimumCount > 1 )
+ cell = cell / minimumCount;
+ else
+ cell = dx;
+ if ( divisions > 1 )
+ cell = cell / divisions;
+ if ( cell < 20 * 1e-07 )
+ cell = 20 * 1e-07;
+ double base = pow( 10.0, floor( log10( cell ) ) );
+ double unit = base;
+ if ( ( 2 * base ) - cell < h * ( cell - unit ) )
+ unit = 2.0 * base;
+ if ( ( 5 * base ) - cell < adjustBias * ( cell - unit ) )
+ unit = 5.0 * base;
+ if ( ( 10.0 * base ) - cell < h * ( cell - unit ) )
+ unit = 10.0 * base;
+ // Maybe used to correct for the epsilon here??
+ int start = floor( minimum / unit + 1e-07 );
+ int end = ceil( maximum / unit - 1e-07 );
+ // Extend the range out beyond the data. Does this ever happen??
+ while ( start * unit > minimum + ( 1e-07 * unit ) )
+ start = start - 1;
+ while ( end * unit < maximum - ( 1e-07 * unit ) )
+ end = end + 1;
+ QgsDebugMsg( QString( "pretty classes: %1" ).arg( end ) );
+ // If we don't have quite enough labels, extend the range out
+ // to make more (these labels are beyond the data :( )
+ int k = floor( 0.5 + end - start );
+ if ( k < minimumCount )
+ k = minimumCount - k;
+ if ( start >= 0 )
+ end = end + k / 2;
+ start = start - k / 2 + k % 2;
+ else
+ start = start - k / 2;
+ end = end + k / 2 + k % 2;
+ divisions = minimumCount;
+ else
+ divisions = k;
+ double minimumBreak = start * unit;
+ double maximumBreak = end * unit;
+ int count = ceil( maximumBreak - minimumBreak ) / unit;
+ for ( int i = 1; i < count+1; i++ )
+ breaks.append( minimumBreak + i * unit );
+ if ( breaks.first() < minimum )
+ breaks[0] = minimum;
+ if ( breaks.last() > maximum )
+ breaks[breaks.count()-1] = maximum;
+ return breaks;
+} // _calcPrettyBreaks
+static QList<double> _calcStdDevBreaks( QList<double> values, int classes, QList<int> &labels )
+ // C++ implementation of the standard deviation class interval algorithm
+ // as implemented in the 'classInt' package available for the R statistical
+ // prgramming language.
+ // Returns breaks based on '_calcPrettyBreaks' of the centred and scaled
+ // values of 'values', and may have a number of classes different from 'classes'.
+ double mean = 0.0;
+ double stdDev = 0.0;
+ int n = values.count();
+ double minimum = values[0];
+ double maximum = values[0];
+ for ( int i = 0; i < n; i++ )
+ mean += values[i];
+ minimum = qMin( values[i], minimum ); // could use precomputed max and min
+ maximum = qMax( values[i], maximum ); // but have to go through entire list anyway
+ mean = mean / (double) n;
+ double sd = 0.0;
+ sd = values[i] - mean;
+ stdDev += sd * sd;
+ stdDev = sqrt( stdDev / n );
+ QList<double> breaks = _calcPrettyBreaks( ( minimum - mean ) / stdDev, ( maximum - mean ) / stdDev, classes );
+ for ( int i = 0; i < breaks.count(); i++ )
+ labels.append( (int) breaks[i]);
+ breaks[i] = ( breaks[i] * stdDev ) + mean;
+ return breaks;
+} // _calcStdDevBreaks
+static QList<double> _calcJenksBreaks( QList<double> values, int classes,
+ double minimum, double maximum,
+ int maximumSize = 1000 )
+ // Jenks Optimal (Natural Breaks) algorithm
+ // Based on the Jenks algorithm from the 'classInt' package available for
+ // the R statistical prgramming language, and from Python code from here:
+ // http://danieljlewis.org/2010/06/07/jenks-natural-breaks-algorithm-in-python/
+ // and is based on a JAVA and Fortran code available here:
+ // https://stat.ethz.ch/pipermail/r-sig-geo/2006-March/000811.html
+ // Returns class breaks such that classes are internally homogeneous while
+ // assuring heterogeneity among classes.
+ return breaks;
+ QList<double> sample;
+ // if we have lots of values, we need to take a random sample
+ if ( n > maximumSize )
+ // for now, sample at least maximumSize values or a 10% sample, whichever
+ // is larger. This will produce a more representative sample for very large
+ // layers, but could end up being computationally intensive...
+ n = qMax( maximumSize, (int) ( (double) n * 0.10 ) );
+ QgsDebugMsg( QString( "natural breaks (jenks) sample size: %1" ).arg( n ) );
+ sample.append( minimum );
+ sample.append( maximum );
+ for ( int i = 0; i < n-2; i++ )
+ // pick a random integer from 0 to n
+ int c = (int) ( (double) rand() / ( (double) RAND_MAX + 1 ) * n - 1 );
+ sample.append( values[i+c] );
+ else
+ sample = values;
+ qSort( sample );
+ QList< QList<double> > matrixOne;
+ QList< QList<double> > matrixTwo;
+ double v, s1, s2, w, i3, i4, val;
+ for ( int i = 0; i < n + 1; i++ )
+ QList<double > tempOne;
+ QList<double > tempTwo;
+ for (int j = 0; j < classes + 1; j++)
+ tempOne.append(0.0);
+ tempTwo.append(0.0);
+ matrixOne.append(tempOne);
+ matrixTwo.append(tempTwo);
+ for ( int i = 1; i < classes + 1; i++ )
+ matrixOne[1][i] = 1.0;
+ matrixTwo[1][i] = 0.0;
+ for ( int j = 2; j < n + 1; j++ )
+ matrixTwo[j][i] = std::numeric_limits<qreal>::max();
+ v = 0.0;
+ for ( int l = 2; l < n + 1; l++ )
+ s1 = 0.0;
+ s2 = 0.0;
+ w = 0.0;
+ for ( int m = 1; m < l + 1; m++ )
+ i3 = l - m + 1;
+ val = sample[ i3 - 1 ];
+ s2 += val * val;
+ s1 += val;
+ w += 1.0;
+ v = s2 - (s1 * s1) / w;
+ i4 = i3 - 1;
+ if ( i4 != 0.0 )
+ for ( int j = 2; j < classes + 1; j++ )
+ if ( matrixTwo[l][j] >= v + matrixTwo[i4][j - 1] )
+ matrixOne[l][j] = i3;
+ matrixTwo[l][j] = v + matrixTwo[i4][j - 1];
+ matrixOne[l][1] = 1.0;
+ matrixTwo[l][1] = v;
+ for ( int i = 0; i < classes; i++ )
+ breaks.append(0.0);
+ breaks[classes - 1] = sample[sample.length() - 1];
+// breaks[0] = values[0];
+ int k = n;
+ int count = classes;
+ while ( count >= 2 )
+ int id = matrixOne[k][count] - 2;
+ breaks[count - 2] = sample[id];
+ k = matrixOne[k][count] - 1;
+ count -= 1;
+ return breaks;
+} //_calcJenksBreaks
#include "qgsvectordataprovider.h"
#include "qgsvectorcolorrampv2.h"
@@ -339,12 +682,17 @@
QgsDebugMsg( QString( "min %1 // max %2" ).arg( minimum ).arg( maximum ) );
+ QList<int> labels;
if ( mode == EqualInterval )
breaks = _calcEqualIntervalBreaks( minimum, maximum, classes );
- else if ( mode == Quantile )
+ else if ( mode == Pretty )
+ breaks = _calcPrettyBreaks( minimum, maximum, classes );
+ else if ( mode == Quantile || mode == Jenks || mode == StdDev )
// get values from layer
QList<double> values;
QgsFeature f;
@@ -354,7 +702,18 @@
while ( provider->nextFeature( f ) )
values.append( f.attributeMap()[attrNum].toDouble() );
// calculate the breaks
- breaks = _calcQuantileBreaks( values, classes );
+ if ( mode == Quantile )
+ breaks = _calcQuantileBreaks( values, classes );
+ else if ( mode == Jenks )
+ breaks = _calcJenksBreaks( values, classes, minimum, maximum );
+ else if ( mode == StdDev )
+ breaks = _calcStdDevBreaks( values, classes, labels );
else
@@ -371,10 +730,28 @@
lower = upper; // upper border from last interval
upper = *it;
- label = QString::number( lower, 'f', 4 ) + " - " + QString::number( upper, 'f', 4 );
+ if ( mode == StdDev )
+ if ( i == 0 )
+ label = "< " + QString::number( labels[i], 'i', 0 ) + " Std Dev";
+ else if ( i == labels.count() - 1 )
+ label = ">= " + QString::number( labels[i-1], 'i', 0 ) + " Std Dev";
+ else
+ label = QString::number( labels[i-1], 'i', 0 ) + " Std Dev" + " - " + QString::number( labels[i], 'i', 0 ) + " Std Dev";
+ else
+ label = QString::number( lower, 'f', 4 ) + " - " + QString::number( upper, 'f', 4 );
QgsSymbolV2* newSymbol = symbol->clone();
- newSymbol->setColor( ramp->color(( double ) i / ( classes - 1 ) ) ); // color from (0 / cl-1) to (cl-1 / cl-1)
+ newSymbol->setColor( ramp->color(( double ) i / ( breaks.count() - 1 ) ) ); // color from (0 / cl-1) to (cl-1 / cl-1)
ranges.append( QgsRendererRangeV2( lower, upper, newSymbol, label ) );
@@ -454,6 +831,12 @@
r->setMode( EqualInterval );
else if ( modeString == "quantile" )
r->setMode( Quantile );
+ else if ( modeString == "jenks" )
+ r->setMode( Jenks );
+ else if ( modeString == "stddev" )
+ r->setMode( StdDev );
+ else if ( modeString == "pretty" )
+ r->setMode( Pretty );
QDomElement rotationElem = element.firstChildElement( "rotation" );
@@ -523,6 +906,12 @@
modeString = "equal";
else if ( mMode == Quantile )
modeString = "quantile";
+ else if ( mMode == Jenks )
+ modeString = "jenks";
+ else if ( mMode == StdDev )
+ modeString = "stddev";
+ else if ( mMode == Pretty )
+ modeString = "pretty";
if ( !modeString.isEmpty() )
QDomElement modeElem = doc.createElement( "mode" );
Modified: trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.h
--- trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.h 2010-09-28 20:41:38 UTC (rev 14307)
+++ trunk/qgis/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.h 2010-09-29 00:26:34 UTC (rev 14308)
@@ -74,6 +74,9 @@
EqualInterval,
Quantile,
+ Jenks,
+ StdDev,
+ Pretty,
Custom
Modified: trunk/qgis/src/gui/symbology-ng/qgsgraduatedsymbolrendererv2widget.cpp
--- trunk/qgis/src/gui/symbology-ng/qgsgraduatedsymbolrendererv2widget.cpp 2010-09-28 20:41:38 UTC (rev 14307)
+++ trunk/qgis/src/gui/symbology-ng/qgsgraduatedsymbolrendererv2widget.cpp 2010-09-29 00:26:34 UTC (rev 14308)
@@ -192,7 +192,13 @@
QgsGraduatedSymbolRendererV2::Mode mode;
if ( cboGraduatedMode->currentIndex() == 0 )
mode = QgsGraduatedSymbolRendererV2::EqualInterval;
- else
+ else if ( cboGraduatedMode->currentIndex() == 2 )
+ mode = QgsGraduatedSymbolRendererV2::Jenks;
+ else if ( cboGraduatedMode->currentIndex() == 3 )
+ mode = QgsGraduatedSymbolRendererV2::StdDev;
+ else if ( cboGraduatedMode->currentIndex() == 4 )
+ mode = QgsGraduatedSymbolRendererV2::Pretty;
+ else // default should be quantile for now
mode = QgsGraduatedSymbolRendererV2::Quantile;
// create and set new renderer
Modified: trunk/qgis/src/ui/qgsgraduatedsymbolrendererv2widget.ui
--- trunk/qgis/src/ui/qgsgraduatedsymbolrendererv2widget.ui 2010-09-28 20:41:38 UTC (rev 14307)
+++ trunk/qgis/src/ui/qgsgraduatedsymbolrendererv2widget.ui 2010-09-29 00:26:34 UTC (rev 14308)
@@ -113,6 +113,21 @@
<string>Quantile</string>
</property>
</item>
+ <item>
+ <property name="text">
+ <string>Natural Breaks (Jenks)</string>
+ </property>
+ </item>
+ <item>
+ <string>Standard Deviation</string>
+ </property>
+ </item>
+ <item>
+ <string>Pretty Breaks</string>
+ </property>
+ </item>
</widget>
</item>
<item row="1" column="2" rowspan="2">
